indyjps
02-27-2020, 09:28 AM
Looking for suggestions on a rear disc brake swap that uses integrated ebrake, drum brake inside of rotor. If Im crazy let me know.
69 camaro with for 9". I had this 9" built in the 90's, with an old school approach. Axles and housing ends are from a 75 Oldsmobile delta 88, redrilled for chevy pattern, axles resplined for 9". This gives a larger bearing than big ford, the axles have a gentle taper instead of the stepped 9" axle. After beating this on the drag strip Im confident in the set up.
Short story, I need to do some fab with these axle ends.
I have used LS1 and LT1 rotors, caliper, brackets Ive picked up over the years if these will work.
Looking for suggestions, car will be manual, need a good e brake. If I have to fab mounts anyway are the LS1 or LT1 the way to go, or is there a better starting point to allow integrated or very good e brake.
