69 rs ss
02-23-2020, 12:34 AM
1970 chevelle pro touring
Posting up my 70 chevelle pro touring project, I purchased the car from the second owner. It was all original, untouched, and unmolested, extremely solid had original paint from 70 and very well kept cAr. California car, stripped it down redid the whole frame ballasted powder coated reassembled. All the work done by professionals weld work is A-1 Fab work as well done by a gentlemen who builds trophy trucks for VOSS motorsports. All the body molding holes marker lights etc have been shaved and smoothed. Mini tubbed, frame fully boxed and notched to fit 345’s out back. Firewall shaved and smoothed. Brand new 12 bolt from moser 4:11 gears narrowed the list goes on everything here to complete car other than interior check the parts list and photos if you have any questions feel free to let me know call or text car is located in San Jose, Ca. I have about 103k invested in the vehicle I’m asking 65k firm
josh
408-396-9101 (tel:408-396-9101)
I purchased the 70 for 16k
Work that has been done to the car...
•SUSPENSION/CHASSIS
Frame blasted and powder coated $700
Moser 12 bolt rear with 411 gearing $3000
Complete Ridetech suspension coilovers, upper and lower arms, strong arm sway bar ect... $5-6000
GeForce crossmember with some $300
ABC performance mini tub kit plus boxed frame $2000
Carbon ceramic rotors and calipers z06 $7500
Hydro tech hydro boost $ 1500
Baer master cylinder and proportioning valve
Brake lines $150
Custom firewall
•ENGINE/TRANSMISSION
Lsa power plant with tr6060 Mgw short shifter $14,500
Ported lsa blower $2000
1000cc fic injectors $800
nick Williams throttle body $850
Btr3 cam $400
Moroso oil pan $300
Upgraded charger pulley and crank pulley
Hedman headers long tube 1 7/8 $900
Centerforce clutch $1800
McLeod hydraulic clutch kit $360
Custom trans tunnel
All emblems and side marker lights have been shaved
•EXHAUST
Complete exhaust from pypes with borla attack mufflers $1500
•FUEL
Ricks gas tank mini tub version with dual 450 pumps $2500
Holley fuel lines and fittings designed for e85 $1300
E85 conversion $400
•RADIATOR/COOLING
Radiator with dual 16in fans $1350
C&r heat exchanger $700
•EXTRAS
original steel 1970 factory SS cowl hood $1500
Ring brothers hood hinges black $795
Ring brothers trunk hinges black $695
Tru relics electric window kit $900
Ididit steering column + install kit $1250
Window molding
American auto wire $700
Engine wiring harness plus ecu $6-800
Complete radiator support
Body mount bushings $200
Ikey push button start kit $380
Headlight assembly
Front grill
Front and rear bumper
Driver and passenger fender
Exterior Body trim
Clayton brake clutch and gas pedals $600
Eddie Motorsport door handles $380
Window molding clips
Complete exterior hardware kit $250
Classic dash gauges plus center trim $1600
Dashboard
17311017311117311217311317311417311517311617311717 31181731191731201731211731221731231731241731251731 26173127173128173129173130173131173132173133173134 17313517313617313717313817313917314017314117314217 3143
I’m sure I’m missing a few more items but I have a ton of money and parts in this car. More pics upon request thx for looking
josh
•SUSPENSION/CHASSIS
Brake lines $150
Custom firewall
Btr3 cam $400
Moroso oil pan $300
Custom trans tunnel
•EXHAUST
•FUEL
E85 conversion $400
•RADIATOR/COOLING
•EXTRAS
Window molding
Headlight assembly
Front grill
Exterior Body trim
Dashboard
