View Full Version : LT4 Wiring harnes
DKz Garage
02-17-2020, 10:54 AM
Looking for some input on the best place to buy a ECM and wiring harness for my LT4 crate engine. GM is out of stock countrywide on these, with no ETA?? That being said, I was wanting to do the GMPP kit as it has everything...gas pedal, O2 sensors, ECM, Harness with fuel controller. TIA for any input/advice.
andrewb70
02-17-2020, 01:15 PM
Speartech is a good, reputable option.
Also, Holley has a new LT4 accessory drive system that packages much better than the OEM accessories.
Schwartz Performance
02-17-2020, 01:57 PM
GM's ETA last I checked, was mid march.
Speartech is the only other good option as Andrew stated, but they're 6-8 weeks usually.
-Dale
DKz Garage
02-17-2020, 07:38 PM
-Dale
Thanks for the input guys.... Speartech seems to be a good option. I saw the Holley Drive kit....looks like a nice set-up.
DKz Garage
02-18-2020, 11:22 AM
Has anyone used Current Performance Wiring for their LS / LT swap? If so, thoughts??
65 drop top
02-19-2020, 12:29 AM
Check out psiconversion.com it looks like they have the harness, not sure if its a complete kit or not, but worth a call.
DKz Garage
02-20-2020, 07:59 PM
-Dale
Thanks Dale..... I see that you are a Holley Dealer...do you stock any of their parts?? Oil pan/engine mounts for LT4??
Dave
csouth
02-21-2020, 01:08 PM
I used Current Performance when I first did my LS swap. Great quality and I would definitely consider them when doing a swap. The only reason I don't have it now is I switched to Holley.
