ra11ysport
02-15-2020, 10:43 AM
Has anyone tried with any success to install Ridetech upper and lower control arms on Speedtech subframe. The only reason I ask is cause I like the Ridetech lca coilover mounts. I’m not a of the little 7/16 bolts and this is purely from a looks stand point. I just like it better.
slimjim
02-15-2020, 09:45 PM
I'm sure it isn't recommended, but I believe the 'protouring' speedtech subframe was designed with stock geometry in mind similar to the ride tech equipment, so it's very possible it could work for you.
But I would be confident to say it would not work with their 'extreme' subframe as it has different geometry altogether.
