View Full Version : Heater Hoses
Perry M
02-12-2020, 08:59 PM
I was going to use O ring EZ Clip fittings for my heater hoses to the VA evaporator through an inline bulkhead fitting but soon realized that the 5/8'' hose ID was too large for the -10 EZ Clip fitting. Should I use refrigerant hose for this purpose? Any suggestions?
eville
02-13-2020, 08:12 AM
I think you need this.
https://www.iimuch.com/collections/ac/products/ez-clip-to-heater-hose-adapter
dontlifttoshift
02-13-2020, 09:21 AM
I have read that post like 9 times and I think I know what you have.
You have a bulkhead plate on the firewall that is threaded on both sides to take an O ring fitting.
If you want to use an EZ clip fitting, you have to use EZ clip hose, #10 size. You would need to convert your engine side to the O ring by pipe thread adapters from Vintage Air.
Or you can buy O ring fittings that fit your bulkhead and use standard heater hose.
Tsaints1115
02-13-2020, 10:57 AM
AN style hose?
Perry M
02-15-2020, 09:25 AM
Thank you for your responses. I have it figured out. Going with beadlock fittings and standard heater hoses.
