View Full Version : Are you guys mounting your hydroboost at an angle????
BobH
02-10-2020, 05:13 PM
Are you mounting your hydro boost at an angle or are you using the manual brake hole in the pedal ?? If so how is your pedal with it pushrod in the top hole ??
BobH
HotWheelz
02-11-2020, 12:14 PM
We will mount my hydro boost-master cylinder entirely under the dash. I will run a bell crank and the mechanism that will make a 90 bend. We are working for a smooth firewall.
BobH
02-13-2020, 04:08 AM
Nice set-up.. Post up pics
1bad68cat
02-18-2020, 09:39 AM
BobH
I'm assuming you're referring to GM applications, but on my Ford/Mercury, I angled my booster using a modified repro Boss 429 booster wedge and modified the brake pedal to mimic the pedal ratio of the 03 mustang cobra I pulled the hydroboost from.
173029
BobH
02-18-2020, 02:43 PM
Good idea..thanks for sharing
