View Full Version : De-Stroked 454 ?
jglover
12-17-2005, 08:29 PM
I’m looking for feedback on my engine plans.
454 2 bolt main block w/ main studs
Eagle 3.75” stroke 4340 crank
Eagle +.25” long rods
10.5 comp. Forged pistons
Brodix Race Rite oval port heads
Solid roller cam ???specs
Team G intake
Reworked 750 Holley DP
I’m looking for a motor to be able to hold its own at the drags and able to turns some RPM’s during an occasional open track event while still being "street-able". Please let me know what you think before I make a mistake...
ProdigyCustoms
12-17-2005, 08:39 PM
That is a 427. Basically a 427 is a 396 crank in a 454 block. Yes it will be capable of turing some Rsssss. You can save a ton of money and buy a factory steel crank number 6223 for $100 or so, and it will take anything you are going to throw at it. She will easlity make 600+ with a 265 / 270 @ .050, mid 650s lift, grind it on 110 to reduce overlap. It should easily turn low 7000RPMs
SStrokerAce
12-18-2005, 06:59 PM
For all the weight of putting that motor in the front of the car you should at least have the cubes to go with it.
I wouldn't worry about spinning a well built big block enough RPM, but if thats what you are after throw a built small block in there, a 400 based motor has the same stroke as that 427.
Bret
