View Full Version : TrueTrac shudders on turns from a stop
rixtrix1
02-01-2020, 05:48 PM
The TrueTrac diff in my 2002 S10 has developed a shudder on left or right turns from a stop. Feels like driving with a spool on street tires. Not too noticeable above 25 or so, but it does want to slide a lot easier then too. I did remove my summer UHP tires for some all season rollers while the weather is colder. Fluid, Valvoline 75w90 gl5 reg , is full and clean. It's about a year old with 5 autoX events and 4K hard street miles on it. Any idea?
Whiteghost66
02-28-2020, 06:05 PM
Are you running the additive?
RT66ProTouring
02-28-2020, 07:11 PM
:pat: If you are, you shouldn't be running it. TrueTracs aren't a clutch type posi and don't want the extra friction.
https://www.eaton.com/us/en-us/products/differentials-traction-control/aftermarket-differentials/detroit-truetrac-faqs.html
Whiteghost66
02-29-2020, 05:24 PM
I know the Ford 9 trak-lok posi units need friction modifier to eliminate clutch chatter when cornering. Each brand has their own specific guidelines.
Tim C
03-02-2020, 02:23 PM
I've currently got a trutrac in the 9" on my Fairlane, and my old tow rig/dd f250 had a trutrac in it's 10.5" rear. Both developed a shudder when turning at an intersection until I added a little friction modifier even though Detroit says not to. Both were running the recommended non synthetic gear oil too.
chevelletiger
03-22-2020, 06:11 PM
Read what ryan said NO CLUTCHES
Tru trac has helical gears,no clutches,so you use standard gear oil.
68Formula
03-22-2020, 06:17 PM
It looks like what you've been using is synthetic. According to Eaton, you're not supposed to use friction modifiers or synthetic oils in their TrueTrac. I'm running non-synthetic in my truck's 8.6" for about 80k miles with no issues.
