View Full Version : Anyone have a pair of AME steering arms they don't need?
Snowcatter
02-01-2020, 03:28 PM
Greetings, I am looking for a pair of steering arms for the AME GT sport with C-6 spindles. Anyone got a set they don't need?
Snowcatter
03-04-2020, 08:29 PM
Bump
Snowcatter
09-11-2020, 05:54 AM
Still looking...
Snowcatter
09-11-2020, 03:48 PM
Or a pair of Detroit Speed ones? Perhaps...
Sleeper68
09-21-2020, 12:23 PM
What is the application? A buddy of mine has alot of C5/C6 stuff laying around
Snowcatter
11-03-2020, 09:40 AM
The steering arms are a bolt on modified steering arm for C6 spindles. The original steering arms are machined off and these bolt on. AME, DSE and others make these for their suspension package. I couldn't use the spindles that come with my morrison front end so I need to source just the steering arms.
Shaun - make sure you get the steering arms for the new style fabricated control arms. They are different from the previous version that was used on the C6 control arms. I would have sold you mine off of a C6 control arm frame if they would have worked.
Snowcatter
11-04-2020, 03:39 PM
I feel confident that the only difference between the two is a wider stance, as in they are bent outwardly which only requires longer tie rod ends. I would rather use the older style and retain off the shelf tie rod ends rather than having to use the AME specific parts. I have already built my own steering arms that work well with my off shelf steering rack and tie rod ends but if I can find a good deal on a pair of AME older style arms I will use them instead.
