View Full Version : Trade for Pro Touring GM: 1972 Chevy K5 with Cummins
grendel
02-01-2020, 07:50 AM
Seems like the K5 market is exploding at the right time for me. I have 3 K5s so this one has to go.
Start with a CA built and raised 1972 Chevy Blazer CST (have all docs) with factory AC (rare) in Ochre (horrible color). We brought it here from CA in 2006.
This is a frame off build. We blew it down to every last nut and bolt.
VE pump Cummins set to 350 hp and 820 ft lbs of torque. All new bearings, seals, rings - ARP head studs, Cometic head gaskets, HE 351 Turbo, Aeromotive and Air Dog fuel management, Bosch 5x14 injectors, 60lb valve springs and a 4" exhaust. Pump was modified, timed and dyno'd by Diesels in BOW, NH. KDP done.
NV4500 - Trans was down to the case, blasted and painted, all new bearings and seals. Upgraded output shaft to manage the crazy nut.
NP205 - 29 spine input, 32 spline outs.
Chevy Dana 60 front - Detroit locker, 3.73 gears, all new bearings and seals. 35 spline all the way through
Corp 14B rear - 3.73s and a true track
We cut all the rot out of the body, sand blasted the frame, added 52" springs in front and 63" springs in the rear, along with a shackle flip. Paint is fresh, like everything else. Waiting to cut and buff it.
Interior is fresh, sitting around in boxes. Owner wanted the bow ties, not hard to change out. Seats are actual K5 along with the center console.
Some build pics here:
https://www.facebook.com/pg/BlueRibb...26161520827872
172426172427172428
(https://www.facebook.com/pg/BlueRibbonAutoRestoration/photos/?tab=album&album_id=1026161520827872)
cwylie
02-02-2020, 05:04 AM
Sales price?
grendel
02-02-2020, 05:54 AM
sales price?
55k
badazz81z28
02-03-2020, 03:13 PM
The new interior is represented? I doesn't look like it. The pictures don't match the description.
grendel
02-03-2020, 04:36 PM
The door panels and seat covers are new, yes. As is the HVAC control, ignition switch, wiring harness, etc.
We're motoring away on the interior. It's why we said the interior is mostly in boxes. Sound deadeener, carpet, side panels, etc.
grendel
01-19-2021, 05:20 AM
We did Vintage Air, Dakota Digital and Ring Bros interior pieces in this. Finishing up the dash mods and wiring now.
Swapped the seats for some nice leather Corbeau LG1's with seat heaters - will get some pics once the dash is painted and recovered.
southernfriedcj
01-19-2021, 03:23 PM
I would recover the original seats with repop original covers, detail the truck to 10/10 and put it on BAT.
Maybe put the exterior trim on it.
Do you have any project Blazers or Jimmys sitting around you want to trade for a '61 Unimog or a '59 Mac B61?
232_ray
01-19-2021, 10:55 PM
Where’s it located??
grendel
01-20-2021, 04:55 AM
New Hampshire
grendel
11-27-2021, 06:42 AM
Well, this has taken a bit of change since I last posted it:
72 Blazer Custom Sport Truck – Factory Air truck
Originally Ochre, bought as a body and frame from CA in 2006.
Rust repaired with OEM panels – no rust – Now black inside and out.
Body:
• Factory CST badging, trim and moldings to be applied.
• Single wall top in very good shape, with a new hatch.
• All new Motorcity K5 glass
• New hydraulic hatch struts
• No rust, all removed/repaired
• Black paint, cured, needs buffed.
• Cowl hood included, not painted.
• Shaved cowl cover in fiberglass, not painted
Interior:
• Gen4 Vintage Air with Magnum controller
• Dakota Digital HDX gauges with boost and EGT
• Ring Bros Billet Dash
• Billet HVAC vents
• Corbeau heated leather seats on k5 brackets
• Rear seat included, needs recovering
• New Port Engineering wiper/washer with delay switch
• Alpine head touch screen with car play
• Ididit Tilt Column with Billet Specialties steering wheel
Suspension:
• ORD shackle flip in the rear, 56” springs
• DIY4x4 52” spring kit in front
• Bilstein 5200 shocks
• H2 rims with 35” Toyo AT’s
Drivetrain:
• 380hp VE pumped Cummins – head studs, valve springs, injectors, and turbo.
• Frame reinforced with correct engine plates and crossmember.
• Dodge based Mishimoto radiator, AC condenser and air charge cooler.
• AC compressor, 180 amp alternator and hydro boost braking system
• Aeromotive 1000 series pump in Tanks Inc stainless 22g tank with Ό skid plate.
• Chevy Dana 60 front with 3.73s gears, disk brakes, high steering arms on knuckles
• GM 11.5AAM rear, 3.73 gears, a new limited slip differential and factory disk brakes.
• Single stick NP205 with 1350 driveshafts
• Currently has an NV4500, can replace with a 47RH
67-LS1
11-27-2021, 07:48 AM
Any updated pics?
Dave_Rob_Can
11-28-2021, 06:25 AM
Body:
Interior:
• Billet HVAC vents
Suspension:
Drivetrain:
Any updated photos? or a build thread? The facebook link does on work.
grendel
11-28-2021, 06:34 AM
We're doing pro pics shortly.
Some build pics https://www.facebook.com/media/set/?set=a.1026161520827872&type=3
