View Full Version : Best LS to supercharge on a budget?
Larry Callahan
01-30-2020, 08:12 PM
Is there a combination of a budget takeout LS motor that would accept a budget supercharger?
I assume not but it can't hurt to ask.
I am kicking around the idea of a budget LS motor for the '55 Bel Air and later down the road supercharging it.
Is there a LS engine that would accept a supercharger from something that maybe has been pulled to replace it with the latest and greatest? For example I hear there may be a new supercharger that replaces the factory LSA supercharger? I could see people replacing the stock LSA supercharger and selling them?
Thoughts?
btmatt
01-31-2020, 07:34 AM
Sloppy Mechanics raves on the LY6 truck motor
68Formula
01-31-2020, 09:35 AM
LY6 has the matching, higher flowing ports (so no rectangle to cathedral port adapter needed). Just do a VVT delete and pick a good positive-displacement compatible camshaft with about .600" lift and matching valvetrain upgrades (springs and rockers).
I'd also update to LS9 head gaskets.
Larry Callahan
02-01-2020, 10:10 AM
Any chance there is an all aluminum version without VVT that an LSA supercharger would drop onto at a later date? I'm trying not to shoot myself in the foot in the future.
68Formula
02-01-2020, 05:27 PM
LS3. But @ 10.7:1 compression, you'd have a fun time keeping donation at bay with a blower.
rentedmule
02-07-2020, 09:45 AM
The L76 from the Pontiac G8 is lower compression than the LS3 but has the same heads. Still need to do a DOD delete but it will accept an LSA.
Larry Callahan
02-07-2020, 03:47 PM
It's crazy how many options there are. Some of them are not crazy expensive.
I think I may just ending up putting a LQ4 and a 4L80 for now and then maybe build something new and complete down the road and just swap it out. I think I may be worrying too much about this.
68Formula
02-08-2020, 02:35 PM
FWIW, if it were me I'd get a take-out LY6, and delete the VVT (not as many parts needed since it doesn't have AFM as well). I think you can get away with the truck intake and accessories on a Tri-5, and it'll have the rectangular port heads to mate to the LSA intake. I wouldn't worry about the weight of the iron block.
Add LS9 stock head gaskets (they are MLS steel). Since the heads are off, you may want to sent them for porting, but that's up to you.
Then I'd upgrade the oil pump, and add a Summit-8715 cam with 1218 PAC springs. This cam will work well naturally aspirated and pair very well when you add the blower later. So you won't have to upgrade the camshaft twice. The other nice thing about going with a cam that works as stock or with the blower, you'll be able to get all the base tuning worked out ahead, minimizing recal later. You could even update with higher flow injectors as this point too.
If you're positive you'll be moving to the blower at a later date, you could get the brackets ahead of time https://www.lsxinnovations.com/product/lsa-6-rib-accessory-drive-truck-belt-spacing/ before you put it in the car. I think it should still work with the truck intake, you'll just need a different length belt.
Doing it this way, you start with a good NA combination that should put out nearly 500hp at the crank (even more of you had the heads ported). Then later you can swap the SC on top (along with the cooler lines) and update the cal for new injectors and boost.
Bruce1968
05-28-2020, 08:32 AM
6.0 engines are good and are popular. But, if doing it on a budget is a real high priority, a 5.3 out of a truck can be found pretty cheaply and can be safely boosted, from what I understand, to a level that will never be able to find traction on the street.
icemanrd19
05-28-2020, 04:54 PM
Budget would be a 5.3, 5.7, 6.0 and put a lsa on top of it. Either swap the heads or use adapter plates. I’m running a 2.3 heartbeat blower on mine peak 9 psi at but typically 7-8psi and it made 700rwhp at 6800rpms. I plan on turning the boost up a few more pounds this winter.
Chirus
06-18-2020, 01:48 PM
Here is a breakdown on what my LY6 + LSA setup has cost so far. There is no need to go as far as i have, but it will give you an idea on costs.
If there is no cost then it was part of a kit. cost will very on these items as i bought mine last year. I bought the LSA several years ago off ebay when they where cheap.
If i did it again i wold look for a complete LSA take out. it is the small hard to source items that eat up the budget. My engine was a GM Core so i had none of the nuts, bolts and clip that a junkyard engine would come with. The take out units i have seen come with the trans as well. so that would save you a bunch in cost as well.
LY6 Engine
Own
$ 700.00
LSA Supercharger
Own
$ 450.00
ZZP
Intake Bolts
LSX-LSASC6M
$ 21.95
LSX Concepts
ZL1 Supercharger Cover
12622236
$ 569.99
ZZP
Supercharger oil
12322236
$ 8.99
ZZP
Supercharger Coupler
ZZ-LSASCCPLR
$ 19.99
ZZP
Throttle body 90mm
12605109
$ 171.99
GM
Fuel Rail
12605222
$ 278.79
RockAuto
Injector harness
12664869
$ 88.11
newgmparts.com
Injector harness
12664870
$ 84.37
newgmparts.com
Fuel Filter
MP-7010-BLK
$ 85.99
Summit
Fuel pressure Regulator
MP-99509-B9-BLK
$ 221.99
Summit
Fuel Injectors 85lbs EV6
FIC-IS303-0850H
$ 675.00
Lingenfelter
Engine Controller
19369381
$ 1,557.00
GM
LSA Modular pulley 2.5
$ 149.99
ZZP
ARP 234-4317 Cylinder Head Stud Kit
234-4316
$ 346.99
ZZP
ARP 234-5608 Main Stud Kit
234-5608
$ 217.99
Summit
ARP 134-6006 Connecting Rod Bolts
134-6006
$ 94.99
Summit
not used
Harmonic Balancer
12674581
$ 131.99
RockAuto
Harmonic Balancer Bolt
12557840
$ 4.12
RockAuto
Oil Pressure Sensor
12673134
$ 36.79
RockAuto
Rear Crank seal and cover gasket
BS40640
$ 16.80
RockAuto
Intake Gaskets
12673134
$ 39.79
RockAuto
Valley Gasket
12610141
$ 40.79
RockAuto
Oil Galley Plug (barbell)
MOGP100
$ 5.26
RockAuto
Oil pump pickup o-ring
B32790
$ 1.68
RockAuto
Rods & Pistons, crank
$ 2,249.00
Texas Speed
Piston -13.7 Dish
Lifters LS7
17122490
$ 99.99
Texas Speed
Valve Springs
12625033
Texas Speed
Rocker Arm Trunion Kit
CHE4290
$ 109.99
ZZP
had to have 4 more shipped
Camshaft kit springs, push rods seals
12638427
$ 919.89
Texas Speed
Camshaft Thrust Plate
MF127
$ 23.79
RockAuto
Timing Chain, Cam kit
Texas Speed
LS9 Head Gaskets
12622033
$ 123.98
Summit
Steam Vent Kit
03-51005
$ 217.00
NO2 outlet
3 Bolt Camshaft Timing Sprocket, Cam kit
12586481
Texas Speed
Timing Cover
12600326
$ 119.00
Texas Speed
Timing Chain, cam kit
Texas Speed
High Mount Accessory Drive
LSA Race Drive High
$ 1,947.29
LSX Concepts
12182
Dipstick
12634547
$ 12.70
Rockauto
Dipstick Tube
12634547
$ 14.15
Rockauto
LS9 Piston Squirters
KAT-6350
$ 183.99
Katech
not used
Timing Chain Dampener
12588670
$ 18.99
Summit
Oil Pan
302-1
$ 349.95
Amazon
Oil Pan Baffle
302-10
$ 168.94
Amazon
Melling Oil Pump
10295
Texas Speed
Radiator
Custom
$ 1,349.00
Entropy
Oil Cooler Lines
625-169
$ 66.95
Dorman
Crank Pin Kit
SLP100250
$ 49.99
LSX Innovations
order #4024
VVT Delete Kit
$ 119.00
Texas Speed
Water Pump
19180610
$ 172.79
RockAuto
Starter
12617229
$ 111.79
RockAuto
Starter Bolts
551681
$ 11.99
Amazon
Thermostat 187 degree
34198
$ 6.57
RockAuto
Fuel Tank
TM48A-T
$ 280.00
Tanks inc.
Fuel Pump
GPA-6
$ 280.00
Tanks inc.
Fuel Sending Unit
TAN-GME
$ 35.00
Tanks inc.
Fuel Door
AD-85
$ 45.00
Tanks inc.
Headers Mid Length 1 7/8"
102-6794
$ 899.00
Brphotrods
order#17958
Stainless Steel Header Bolts
000-6730-00
$ 24.99
Brphotrods
Oil Pump Pickup Tube Girdle
000-6000-00
$ 34.95
Brphotrods
not used
AFCO Heat Exchanger
80283NDP
$ 459.18
Summit
MSD Coil
MSD32823
$ 352.95
Summit
MSD Spark Plug wires
MSD55118
$ 83.35
Summit
3/8 Fitting Fuel Line
EAR-AT165006ERL
$ 22.66
Summit
1/4 Fitting Fuel Line
FRA-892004BL
$ 25.98
Summit
Trans Mount Ploy
000-2960-56
$ 39.99
Brphotrods
Total
$ 17,051.12
Engine work Larry's Engine and Marine, Tuscon
Mod block for Oilers
$ 200.00
Oil squirters
MLR 401-326
$ 108.00
Cam bearings
CH-25
$ 25.85
Hone V8
$ 75.00
Jet Clean block
$ 75.00
install cam bearings
$ 70.00
LS O galley plug
9427693
$ 5.54
Main bearings
MS2199P-STD
$ 116.94
Enviromental Fee
$ 5.54
Total
$ 681.87
Tools
Ring filer
PRO66785
$ 56.99
Spring compressor
TFS90306
$ 79.99
Ring compressor
ARP 900-0100
$ 60.40
Magnetic Base
Harbor Freight
$ 13.00
Tread Tap
ARP 912-0011
$ 53.60
$ 263.98
D-Man
07-31-2020, 11:24 AM
LY6 Engine
Own
$ 700.00
LSA Supercharger
Own
$ 450.00
ZZP
Intake Bolts
LSX-LSASC6M
$ 21.95
LSX Concepts
12622236
$ 569.99
ZZP
Supercharger oil
12322236
$ 8.99
ZZP
ZZ-LSASCCPLR
$ 19.99
ZZP
Throttle body 90mm
12605109
$ 171.99
GM
Fuel Rail
12605222
$ 278.79
RockAuto
Injector harness
12664869
$ 88.11
newgmparts.com
Injector harness
12664870
$ 84.37
newgmparts.com
Fuel Filter
MP-7010-BLK
$ 85.99
Summit
MP-99509-B9-BLK
$ 221.99
Summit
FIC-IS303-0850H
$ 675.00
Lingenfelter
Engine Controller
19369381
$ 1,557.00
GM
$ 149.99
ZZP
234-4316
$ 346.99
ZZP
234-5608
$ 217.99
Summit
134-6006
$ 94.99
Summit
not used
Harmonic Balancer
12674581
$ 131.99
RockAuto
12557840
$ 4.12
RockAuto
Oil Pressure Sensor
12673134
$ 36.79
RockAuto
BS40640
$ 16.80
RockAuto
Intake Gaskets
12673134
$ 39.79
RockAuto
Valley Gasket
12610141
$ 40.79
RockAuto
MOGP100
$ 5.26
RockAuto
B32790
$ 1.68
RockAuto
$ 2,249.00
Texas Speed
Piston -13.7 Dish
Lifters LS7
17122490
$ 99.99
Texas Speed
Valve Springs
12625033
Texas Speed
CHE4290
$ 109.99
ZZP
12638427
$ 919.89
Texas Speed
MF127
$ 23.79
RockAuto
Texas Speed
LS9 Head Gaskets
12622033
$ 123.98
Summit
Steam Vent Kit
03-51005
$ 217.00
NO2 outlet
12586481
Texas Speed
Timing Cover
12600326
$ 119.00
Texas Speed
Texas Speed
LSA Race Drive High
$ 1,947.29
LSX Concepts
12182
Dipstick
12634547
$ 12.70
Rockauto
Dipstick Tube
12634547
$ 14.15
Rockauto
KAT-6350
$ 183.99
Katech
not used
12588670
$ 18.99
Summit
Oil Pan
302-1
$ 349.95
Amazon
Oil Pan Baffle
302-10
$ 168.94
Amazon
Melling Oil Pump
10295
Texas Speed
Radiator
Custom
$ 1,349.00
Entropy
Oil Cooler Lines
625-169
$ 66.95
Dorman
Crank Pin Kit
SLP100250
$ 49.99
LSX Innovations
order #4024
VVT Delete Kit
$ 119.00
Texas Speed
Water Pump
19180610
$ 172.79
RockAuto
Starter
12617229
$ 111.79
RockAuto
Starter Bolts
551681
$ 11.99
Amazon
34198
$ 6.57
RockAuto
Fuel Tank
TM48A-T
$ 280.00
Tanks inc.
Fuel Pump
GPA-6
$ 280.00
Tanks inc.
Fuel Sending Unit
TAN-GME
$ 35.00
Tanks inc.
Fuel Door
AD-85
$ 45.00
Tanks inc.
102-6794
$ 899.00
Brphotrods
order#17958
000-6730-00
$ 24.99
Brphotrods
000-6000-00
$ 34.95
Brphotrods
not used
AFCO Heat Exchanger
80283NDP
$ 459.18
Summit
MSD Coil
MSD32823
$ 352.95
Summit
MSD55118
$ 83.35
Summit
EAR-AT165006ERL
$ 22.66
Summit
FRA-892004BL
$ 25.98
Summit
Trans Mount Ploy
000-2960-56
$ 39.99
Brphotrods
Total
$ 17,051.12
$ 200.00
Oil squirters
MLR 401-326
$ 108.00
Cam bearings
CH-25
$ 25.85
Hone V8
$ 75.00
Jet Clean block
$ 75.00
$ 70.00
LS O galley plug
9427693
$ 5.54
Main bearings
MS2199P-STD
$ 116.94
Enviromental Fee
$ 5.54
Total
$ 681.87
Tools
Ring filer
PRO66785
$ 56.99
Spring compressor
TFS90306
$ 79.99
Ring compressor
ARP 900-0100
$ 60.40
Magnetic Base
Harbor Freight
$ 13.00
Tread Tap
ARP 912-0011
$ 53.60
$ 263.98
That's super helpful. Thanks for sharing! One question. Out of those parts what big ticket items can be eliminated for a budget build and still remain durable?
F-Body International
08-01-2020, 01:22 AM
It’s not the most cost effective but GM Performance has a small bore rectangle port cylinder head. You could technically bolt up to an LS1. The aluminum L33 has too small of a bore for this unfortunately.
Chirus
08-04-2020, 08:22 AM
If the focus of your build is to add to the engine in stages. I would focus on bottom end upgrades first.
The largest issue i ran into has been finding the small parts, clips, brackets and harnesses. i would look to a complete LSA takeout engine.
214Chevy
08-27-2020, 10:46 AM
I honestly don't think the words "budget" and "supercharger" actually go together.
andrewb70
08-27-2020, 01:50 PM
Depends on the size of the budget...LOL
