View Full Version : LSA Coolant in Oil Pan
joeko23
01-26-2020, 08:29 AM
Hey guys I bought a pullout LSA from a 2015 wrecked ZL1, I pulled the oem oil pan to put on the Holley one and to my surprise there was some milkshake. I was told the engine has only couple thousand miles so I doubt there is a cracked head/block from overheating etc. plus the engine is completely stock no power adders. The only damage I have found is the oem exhaust manifold on the drivers side was slightly warped at the mating surface. Heads are not warped because my new manifolds have a tight fit. Also the bolts for the manifold were warped as well. I see no other damage. The engine turns freely. Most likely the car rolled several times. Would that cause coolant to spill into the oil pan?
cwylie
01-26-2020, 09:13 AM
Are you sure it was coolant and not just water from sitting in the junk yard?
joeko23
01-26-2020, 09:36 AM
How would water get into a sealed engine?
eville
01-26-2020, 09:37 AM
Condensation. Was the engine stored covered? Through the intake?
Snowcatter
01-26-2020, 09:52 AM
I would be very concerned about that...these engines are all aluminum which doesn't fare well when impacted in a crash. If that manifold was bent it could have easily damaged the head on that side or sprung the head gasket. Probably should check that head very carefully.
Snowcatter
01-26-2020, 09:55 AM
Also of note, if you want to retain the LSA oil cooler the Cadillac LSA oil pan is the way to go. It has very similar dimensions as the F-body pans and has the mounting lugs for the oil cooler.
joeko23
01-26-2020, 10:00 AM
I don’t know how it was stored, when I received the engine all ports/holes were covered with plugs, tape plastic wrap. I really don’t think it’s water from just sitting around. If it was just water there would be a separation of water/oil. This was like a milkshake color so the engine had to be on at least for a few seconds/minutes when the water/coolant got into the oil pan. At least that’s my thinking. Am I wrong in that theory? Water and oil doesn’t mix unless it’s mixed right?
eville
01-26-2020, 02:20 PM
Did you contact the seller?
Snowcatter
01-26-2020, 02:56 PM
Milkshake means it was running with water in the oil
dhutton
01-26-2020, 05:06 PM
Hook up the radiator and pressure test the cooling system. Don’t forget to hook up the steam vent.
Don
joeko23
01-26-2020, 05:15 PM
Does anyone think the physical act of the car/engine rolling over put coolant in the oil system?
eville
01-26-2020, 08:11 PM
nope.
