View Full Version : Six speed and Five speed value
Benttube
01-22-2020, 06:18 AM
Got three transmissions that I have accumulated over the years that I am going to let go of to get something that better suits my current plan. Could use some help with value of these trans.
Richmond 4+1 with shifter, bell housing, hydraulic setup, flywheel and clutch, set up for LS
LT-1 T56 six speed, includes bell housing and clutch
ZF six speed out of corvette, has bell housing and clutch but very back tail housing is broke
Any help is appreciated
Alwhite00
01-22-2020, 10:42 AM
Is the 4+1 an overdrive trans?
Benttube
01-22-2020, 10:57 AM
I am pretty sure the Richmond 4+1 is just 1:1 in high gear. Someone else may chime in with a definitive way to tell. It has Richmond 4+1 cast into the side of the case.
WallaceMFG
01-22-2020, 11:42 AM
The 4+1 is NOT an overdrive trans. Gears 1-4 are underdrive, 5th gear is 1:1. A Richmond ROD is the same as this, but with a 6th gear that is OD.
The 4+1 is a good strong trans, but the rear end has to be geared right to use it. I've seen them listed on CL for $2,000 before, not sure on actual value though.
LT T56 needs the bellhousing, input shaft, and front plate replaced to work with an LS engine. You can probably get $1,000 - $1,500 for that.
ZF 6 Speeds come up on ebay in the $1,500 range in various conditions. Expect less if it is damaged.
Hope this helps.
Benttube
01-22-2020, 12:31 PM
Thank you Nelson, definitely gives me a some good starting points.
