View Full Version : Billet Side View Mirrors for C10 Sport Mirror, GM Universal and Ford Universal Mount
Billetrides
01-13-2020, 06:40 AM
• 2 Different Universal Mounting Systems (Ford has 3)
• Mount from outside of vehicle through the inside of our base
• Mount from under our base with innovative slide mounting track
• Up to 3 5/8” hole spread distance capability (Ford is 5 1/2")
• Convex Automotive Glass for large field of view
• Ability to tighten the Pivot ball
• Perfect finish quality Polished, Anodized Gloss or Flat, Matte/Polished
• 6061-T6 Aluminum
• Made in The U.S.A.
• Sold in Pairs
Billet Rides Newest Innovative Mirror is now available for Trucks. Based off of a 73-87 GM design but with infinite flexibility for mounting and vehicle options. Our newest base design gives the ability to mount through the inside of our base to the top of your door or from under our base using our newest flexible distant slide mounting track design. You will be able to slide your mounting fasteners from underneath to the exact hole distance on your door. Mirrors will come with provided gaskets and hardware to make your installation easy. These mirrors have been designed with the goal of mixing style, elegance, and functionality. Using 6061-T6 aluminum we crafted these mirrors to outperform any original factory mirror with utilizing Convex Glass, the amount of articulation, style and with the ability to tighten the tension on the pivot ball. This mirror will fit almost anything and has been designed to eliminate the negatives of cheap factory mirrors.
