View Full Version : Need ideas
Fugzilla
12-30-2019, 03:51 PM
I have a 2000 Chevy Silverado z71 with an lm7. I’m looking to beef up the engine and suspension, also looking to go AWD or if possible a way to select between AWD, 4x4 and 2wd instead of staying traditional 4x4 or 2wd 171033
TheJDMan
12-30-2019, 03:55 PM
Sounds to me like you need to find an appropriate donor truck.
Fugzilla
12-31-2019, 03:51 AM
Don’t see how I would need a donor truck this one is solid. 200k on the block and still runs like new, no punckieness or holes in the frame. Like I said solid all I need to know is what transfer case or diffs that would work
astroracer
12-31-2019, 06:53 AM
Your truck is 2wd now? Do you already have a 4x4 transmission? Do you have a 4x4 front suspension? Do you have the 4x4 drive shafts? Do you have the 4x4 ECU, harness and all of the connectors? This is a money pit that I doubt you really want to get into. This swap involves a whole lot more the a transfer case and diff...
Buying a 4x4 truck would be your cheapest and easiest way of getting this done. If you still want to undertake the changeover, a donor truck, just like Steve suggested, will get you everything you need to do the swap and get it running. Add to the cost of the swap the rebuilding or replacing of worn out parts like CV joints, ball joints, u-joints, transmissions and transfer cases...
In my experience this is a recipe for frustration with no real gain. Sell your "solid" 2wd and don't look back. As rusty as it is I think you will find a lot of issues with the frame as soon as you open it up.
I just want you to think this through and realize this is not a simple task... :)
Mark
Fugzilla
12-31-2019, 07:00 AM
Mark
Oh it’s a 4x4 lol
Fugzilla
12-31-2019, 07:29 AM
Oh it’s a 4x4 lol
Also was planning on replacing everything that needed replacing just looking for advice on what parts I should look for ( I do work in a salvage yard)
astroracer
12-31-2019, 07:52 AM
Ah, I see, your initial post made it sound like you were wanting to go 4x4 or AWD from a 2wd...
The mid-2000 Trail Blazers and Envoy Denali's with the V8's were part time 4x4 with 2wd as the normal mode. Their T-case should bolt up to your LM7. You will need the computer and all of the wiring as well. I don't know if the 4x4 mode ties into the anti-lock brake system or not or what changes would need to be made to the GMT360 ECU to work in the truck...
Mark
Fugzilla
12-31-2019, 09:15 AM
Mark
And there won’t be any binding issues? also I have a 4auto selection I’m looking to do full AWD as an option to the 4x4 hi,low,auto and 2 hi .... if that makes sense also I’m not afraid of a challenge
astroracer
12-31-2019, 12:06 PM
Binding issues? Binding with what?
Do you know what AWD is? AWD is what comes on the Astro and Safari vans, S10's and Blazer's. AWD is ON ALL the time... You cannot turn it off... You already have 4wd and the ability to go 2wd by pressing a button. I don't understand what you are wanting, needing, thinking you can do to make a 4x4 drivetrain into an AWD and why that would be better or any different then what you are already using... Can you explain it better?
Very confused in MI...
Fugzilla
12-31-2019, 12:28 PM
Ok so with 4wd you get full power to all 4 wheels not good for driving on dry pavement with awd the power goes where it is needed thus better handle and traction idk how to better explain it (4x4 4wd and 4 auto are not awd)
(4x4 100% power to front and back )
(Awd you get a percentage of rear to front)
Im looking into this to make my truck a little more versatile for work and fun
astroracer
12-31-2019, 02:03 PM
Okay, I understand. My '94 Astro has AWD and my '08 Envoy is 4x4 or 2wd. I see no difference driving either one of them on dry pavement other then the Astro (LT1 350) won't spin a tire from a dead stop. The Envoy has a 5.3 and it will spin the back tires in 2wd mode and in 4x4 it won't... The two transfer cases and drive mechanisms are entirely different, I don't see how they can be intermingled to do what you are wanting to do...
I think the Astro transfer case is an NP136? I know guys are swapping in S10 NP233 cases to get the 4x4 locking 4 Hi and locking 4 Lo. I don't know if that case is AWD or simply 4x4...
Good luck with your project.
Mark
raustinss
12-31-2019, 02:36 PM
Silverado ss transfer case ??? Not sure what you think you need to beef up gm drivetrains in those trucks are already pretty stout and can take a $#it kicking . I know a guy who's got a single turbo 900 wheel Silverado and hes just at the busting cv joint stage
Fugzilla
12-31-2019, 03:53 PM
Mark
Yea fasterproms on YouTube has an awd s10 project kinda how I desired I wanted to go awd .... as far as the burnouts on awd you need a lockout for the tif to put all power to main drive wheels if you watch keenblocks hoonacorn makeing the only way he could do a burnout at a dead stop was if he had it chained
Jaymzz
12-31-2019, 04:02 PM
Not really familiar with what 4x4 stuff you already have in your truck but my Trailblazer SS is awd so might be able to use a transfer case from one of those.
raustinss
12-31-2019, 08:47 PM
Well I'd be saying that unless you got your truck like ken blocks or Jeremy's s10 ... you're going to need well over 1000 hp to get similar results at a minimum. At that point I'd say you're going to have other things to worry about first . If you want a quick fun street truck . Chuck a supercharger on yours and a awd transfer case from a Silverado ss .
Fugzilla
01-01-2020, 05:43 AM
I’m not looking to get to ken block or Jaremys status with the truck just something I can play in the corners with that will be more stable. In hp numbers I’m looking for around 450 to 700hp. The ken and Jeremy thing was in reference to the burnout statement
raustinss
01-01-2020, 04:02 PM
Well 450 to 700 is a heck of a range but ok ,I'd still stick with what I said a bolt on charger , maybe head and cam work too . Stick a SS transfer case in it and maybe lower it too . Relatively simple lol
Fugzilla
01-02-2020, 07:33 AM
Honestly 450 is easy tones of guys have budget lm7 builds over 450 besides I was planning on a cam and spring swap and forced induction of some sort also possibly bag or some kinds of adjustable suspention
