View Full Version : Harmonic balancer ac pulley
1985olds
12-21-2019, 12:31 PM
I have an ati balancer I am installing on my L76. It has the second pulley for the ac, but with my holley bracket I do not use the second pulley. Can I and is it worth it to remove the second pulley It just bolts on? I would have to hone out the holes on the balancer though to run bolts in the pulley holes. The pulley weighs about a pound.
badazz81z28
12-21-2019, 03:56 PM
Personally I would just run it as is, it just won’t be used. I did this in my LS1 when I ran a AC relocation bracket to the upper passenger side. If I recall correctly there are bolts that are longer that go through the front pulley through the hub to the rear pulley. You should be able to not even use it without mods, you’ll just need shorter bolts. But ask ATI to be sure.
1985olds
12-21-2019, 04:24 PM
You are correct on the longer bolts. The holes need to be opened up a little for a larger bolt. I spoke to ati twice and one tech rep said no, one said yes. I'm wondering if the juice is worth the squeeze to save 1 lbs of rotating weight
badazz81z28
12-21-2019, 04:40 PM
I honestly don’t recall that AC pulley even weighing that much being aluminum. I ran it with no issues, to avoid the headache either run it or look for a non AC version.
1985olds
12-21-2019, 04:44 PM
I had it on the scale, it is 1 lbs. I think you are right, I'll save the $10 on new bolts and run as is. Thank you.
