De-noz
12-20-2019, 04:38 AM
I play with idea to change to bigger studs in conjuction with adpter or a spacer but not sure which was the best solution...for me.
Car would be a 90% Street car ( 65 oLDS with BMW 4,73"--120mm bolt pattern wheels) with only a few laps here in Germany in the year at the track -but maybe with some semi slicks in the future.
At the rear - SOLUTION 1. - corrected the bolt pattern but use the stock studs from the axle flange
new Studs 7/16-20" ---> 1" thick custom billet Adapterplate which convert from GM(120,65) to BMW (120) pattern ---> and the BMW Wheels bolt to adater with M12x1,5 or M 14 x1,5 Bolts or Studs
At the rear - SOLUTION 2. - use the stock GM bolt pattern but with thick studs
Long 1/2" Studs ARP/Moroso ---> 1" thick spacer ---> bolt the BMW Wheels with lug nuts ( maybe exended version?)
I read this about the Adapter -which convert the bolt pattern
They MUST be double hub centric. Meaning the spacer centric on the hub and the wheel centric on the spacer
Is this correct?
Is this correct?
