View Full Version : Speartech LS1/6 & T56 Standalone Signature Series Harness & 411 PCM
jwcarguy
12-17-2019, 01:42 PM
I have a near new Speartech Signature Series Standalone Engine Harness for LS 1/ 6 / Vortec w/ DBC TB & T56 trans with a #411 pcm
The harness was installed on engine, but build changed directions and went to boosted stroker w/ 58x crank and removed
This is their "signature series" with braided loom
Harness has electric fuel pump relay and feed, elec fan outputs, OBDII port, EV1 injectors, drive by cable TB plgs, LS2 5 pin MAF plug, two O2 plugs
"411" PCM included
Wiring instructions from Speartech are included
$680 SOLD!!
pm/ call/ text (702)677-4085
CarlC
12-18-2019, 11:17 PM
In your second photo it shows the ECM plugs. Can you please measure the distance from the screw that holds the plug (basically the center of the plug) to the the portion of the harness where all the wiring comes out for the backup lights, crank sensor, etc?
Thanks.
Steve68
12-19-2019, 04:57 AM
sent you a txt, thanks Steve
jwcarguy
12-19-2019, 08:07 AM
Thanks.
Carl, you want to know what the "Trunk length" is, then?
I will take it out of package and measure it, in a minute
- - - Updated - - -
replied to text
thanks, Jeff
jwcarguy
12-19-2019, 08:19 AM
Thanks.
CarlC the trunk length is 3'8" (44") from center of ecm plugs to wiring for backup, crank sensor, etc
Thanks, Jeff
jwcarguy
12-19-2019, 08:35 AM
SOLD!!
Thanks, Steve68
Steve68
12-20-2019, 04:54 AM
Thanks Jeff
Carl if you need any other measurements just let me know,
