View Full Version : Best wheel and tire size for a 66 Chevelle
magic32
12-11-2019, 08:49 PM
Hey guys. I have a 66 Chevelle Pro Touring build. I am running 18s front and 20s rear right now and I'm thinking about changing. What do you think is the ideal wheel and tire size for aesthetics as well as function? Thanks
TheJDMan
12-15-2019, 10:44 AM
18s front and rear!
shelteredchevelle
12-15-2019, 01:08 PM
Call me biased, but I kinda like 18's all around. Fronts are 9" , will be 275's when I'm done, currently 255.Rears are 335/35/18 on 12" rims
c4racer2
12-15-2019, 05:16 PM
I agree. 19-20” doesn’t look right on a chevelle or Camaro IMO.
18”. 245/275 or whatever fits. I run 275/295 on my second gen Camaro on 18x10s.
Reckn8
12-16-2019, 03:57 PM
I like the look!! What are the specs on these wheels and tires???
Alwhite00
12-16-2019, 05:11 PM
235/45 & 275/40 18’s
Alwhite00
12-16-2019, 05:14 PM
Front view
pitts64
12-19-2019, 07:04 AM
14" look best. If only you could find tires like we used to have.. 15" are the best looking. Those big wheels are out of scale on these older cars..
On my 69 el Camino I have the SC&C Stage 3, Lee 14:1 with Spohn delsphere control arms in the back and the handling is amazing using plain old 225/70r15 Cooper Cobras..
I am using Porterfield pads and brake shoes with the stock disc/drum set up and it stops good enough for me..
170502
magic32
01-03-2020, 07:52 PM
Hi. Did those fit without any modifications? I like those sizes.
Brentnicolson
02-25-2020, 06:50 AM
hey jim. just curious the back spacing you figured out for the wheels and whether you had to modify the frame to keep the 10' and wider tires on rear from rubbing? thks .
jmking9
02-28-2020, 07:55 PM
Hi. Did those fit without any modifications? I like those sizes.[/QUOTE
Other than rolling the rear fender lips, yes. The 295s are a very tight fit though.
[QUOTE=Brentnicolson;1323014]hey jim. just curious the back spacing you figured out for the wheels and whether you had to modify the frame to keep the 10' and wider tires on rear from rubbing? thks .
Im not Jim, but im guessing you're asking me. The rear backspacing is 5.00" BUT My rearend is narrower than a stock 67 a-body, so my rear backspacing is unique to this car. The 10" wheel and 295 is a pretty tight fit. In my opinion, fitting this size requires wheel lips mods, and a wheel fitment tool to make sure you are getting it exactly right. The backspacing on the fronts are 4.75" Hope this helps.
65 drop top
02-29-2020, 11:15 PM
I went with 19’s and 20’s on my 65. Maybe 18’s would handle a little better, but I don’t track the car. I like the way the wheels fill out the wheel wells.
JBoxJohnny
10-03-2022, 01:08 PM
Hey ShelteredChevelle?
Great set up with those wheels and tires.
What offset/backspacing are you using?
shelteredchevelle
10-03-2022, 04:35 PM
Thanks. This is the finished car. I went with A.R. VNCL405- 18 x 8.5 w/ 4.5 BS Front 18 x 12 w/4" BS rear. My rear housing is 56" wide. 335/30-18 & 265/60-18
hammer136
10-05-2022, 02:54 PM
Looks very nice, I looking for a 66 or 67. If you know of any let me know
mervechikorr
11-17-2022, 12:48 AM
Sclouis
04-16-2023, 05:30 PM
Is your car mini tubbed? It looks great. What is the rear wheel backspace
