View Full Version : Gm 12662757 starter for Z28
badazz81z28
12-10-2019, 05:03 AM
Does anyone have a clue why this GM starters application is only for the 2014-15 LS7 Z28 Camaro? Seems odd to me....
badazz81z28
12-12-2019, 07:14 PM
Same starter used on the new LT1. It’s smaller and has a different connector for the solenoid which would explain why it’s not compatible with earlier LS applications.
badazz81z28
12-15-2019, 08:16 AM
Same starter used on the new LT1. Itís smaller and has a different connector for the solenoid which would explain why itís not compatible with earlier LS applications.
Hereís the difference. Might be a worth while y
typical LS1 starter upgrade.
Motobrewmaster
12-15-2019, 08:28 AM
Thanks for the info. My question would be will it fit in the Quick Time Bell Housing. https://www.holley.com/products/drivetrain/bellhousings/chevrolet/parts/RM-8020
badazz81z28
12-15-2019, 08:35 AM
as soon as I get my new bolts, Iíll find out. I have a LS7 with the QuickTime. Right now I see no reason why it wouldnít.
badazz81z28
12-16-2019, 03:35 PM
installed it today, no issues. Waiting on my heat shield to connect the wires and ensure it all works harmoniously
John McIntire
12-16-2019, 06:56 PM
Nice, look at that, smaller and more compact!
badazz81z28
12-19-2019, 05:27 PM
Works great, sounds like it has more power. But that may because my old starter was not in good health
Motobrewmaster
12-20-2019, 04:30 AM
Great info about the fit for your starter. I will consider one of these in the future when mine dies. I had to take some material off my Quick Time bell housing and the starter to get them to fit. I am using the GM 28-12617229 - LS3 Starter and it would have not fit without the clearancing.) Not sure what the reasoning for it not fitting maybe it is my combination i.e. LSA block with the Quick Time housing.
badazz81z28
12-20-2019, 01:24 PM
Must be something about that starter. The starter that was on my LS1 was a standard LS starter. I moved it over to the the LS7 and no issues and now this smaller Z28 starter with no issues. All three applications were using a Quicktime Bellhousing.
