Jdinjax
12-09-2019, 07:00 PM
Fellow enthusiasts, you ever get the urge to start another project?....yes it's a rhetorical question ;o)
I have several completed cars and I don't think I can suppress the urge for much longer. I'm contemplating letting one of my favorites go, and letting someone else really enjoy her. While she is driven on a regular basis, she is in a rotation that honestly, just doesn't make sense to keep her in the stable.
What do you reckon the market is bringing on such an example? The pictures below doesn't do her justice. She is more stunning in person.
This particular Camaro has a history with several forum members here. There have been several refinements that I have implemented over the years of ownership (Stereo, interior, rewiring, etc).
Below is an ad that I have queued up to eventually post. Thoughts? Is $55-60K reasonable?
1971 Camaro Z28 RS
https://static1.pt-content.com/images/pt/2019/12/kUObDaN9H7HjN2fsYY5Rult4KQyU0635pjIGvNme-1.jpg
1971 Camaro Z28 RS that looks as good as it performs. Not a trailer queen, but can easily pass as one. She is built to run and is well sorted out. True “pro-touring” build with all the right components from the leaders in the industry.
Body and paint 9/10:
-PPG Dodge Viper GTS blue paint w/ white rally stripes. Painted over 12 years ago and still free of any blemishes and imperfections! Typical small rock chips on lower valence, but touched up and not noticeable. No scratches, dings, dents, etc. Original sheet metal, to include trunk pan and floors that were and remain 100% free of rust. The fact that the paint is in perfect condition is testament to the prep and work done prior to shooting it with color.
-Underside of the body was stripped, prepped and sealed with Rhino Liner.
-2" cowl hood (all steel)
-DSE minitubs
-Billet door jamb vents
-Billet door jamb strikers
-Optima Red top battery relocated to trunk
-Billet battery hold down
-DSE fender braces
-Ricks SS fuel tank with walbro 225 pump
-Smoothed firewall
Engine/trans 10/10:
-LS3 w/ custom tune and GM hot cam. (great lope at idle)
-4L70E trans
-Billet fuel rails
-Street & Performance headers
-Custom cold air intake
-MSD starter
-Lokar transmission dipstick
-Custom 2.5 over the axle stainless exhaust with Magnaflow muffler
-PRC radiator w/ aluminum shroud and SPAL fans
-Custom radiator support and closeout
-KWIK a/c bracket
-PSI engine harness
Suspension 10/10:
-Ridetech 4 link out back with Ridetech coilovers
-Hotchkis drop front springs with Vari-shock coilovers
-Hotchkis tie rod adjusters
-SPC upper and lower a arms
-DSE 600 steering box
-Hotchkis subframe strut braces
-Hotchkis subframe connectors
-Ford 9" rear end 373/true track
-Strange carrier with billet yoke, posi and 3.70 gears
-Moser 31 spline axles
Wheels/Brakes 10/10:
-Forgeline ZX3 step lip 18x8 and 18x12 wheels
-BFG KDW tires 245/40-18 and 335/30-18
-Wilwood 13" 6 piston brakes
-Wilwood 12" 4 piston brakes
-9" dual diaphragm booster with DSE low angle brackets
-Wilwood 1-1/8 master
-Wilwood prop valve
Interior 9.5/10:
-Leather (real) Recaro Sportster CS heated seats with custom matched rear seat (note: exterior pics are with Corbeau A4 seats that were previously installed)
-Dakota Digital VHX gauges carbon with blue lights
-Morris Classic 3-point seat belts
-Vintage Air Gen IV air conditioner/heater
-Door panels, carpet, console, dash all in excellent shape w/ Clayton Machine Works cranks
-Alpine head unit
-Alpine front/rear components and Alpine 10” subwoofer w/ JL Audio amp mounted to package tray
-Budnik GTV steering wheel
https://static1.pt-content.com/images/pt/2019/12/sATV5lYNmRuwX1jWX2lvgodx3b0w2WxMSKmutPFO-1.jpg
https://static1.pt-content.com/images/pt/2019/12/9m7iQldq3s2mxGcmcM9WeWmKXCnEFRpvfEtjxTMQ-1.jpg
https://static1.pt-content.com/images/pt/2019/12/IWJJXln3KJxmsiIVXVJh4lHpvRVg221cPCGnIfCA-1.jpg
https://static1.pt-content.com/images/pt/2019/12/wf6GqncIEBhHTS_5dFs7ngb8HRoQINrNNig40T73-1.jpg
https://static1.pt-content.com/images/pt/2019/12/UdmxkdkmRqgTTALSVc3gykMpqtiJCe64sDN0nNg8-1.jpg
https://static1.pt-content.com/images/pt/2019/12/wtWXIIgEAI3yyYUDOaDV5tFxaqzS4ZzJ_Y8TQVdC-1.jpg
https://static1.pt-content.com/images/pt/2019/12/8lhygRG1bfEKjol7nWkf2Sxjdm4uH6CILkP50zJA-1.jpg
1971 Camaro Z28 RS
-DSE minitubs
-DSE fender braces
-Smoothed firewall
Engine/trans 10/10:
-4L70E trans
-Billet fuel rails
-MSD starter
-KWIK a/c bracket
-PSI engine harness
Suspension 10/10:
-Wilwood prop valve
Interior 9.5/10:
-Alpine head unit
