View Full Version : 64 falcon 1jz project
1jzfalcon
12-05-2019, 12:28 PM
Hello. Here are some pics of my project. Been working on this car in my spare time
for a while now. I just started the engine the other day. Still have tons to do and I will update the progress as I go. I also have a video of the engine on instagram. #1jzfalcon. I started with a 64 falcon four door. the engine was knocking and needed a rebuild. I didn't want to use the stock engine. I wanted to build a car that was reliable,powerful, and fun to drive. I also wanted something that my wife could get in and drive without any issue. I have been a Toyota tech for 23 years and have always loved the jz series engines. So i found a 1jzgtevvti engine and transmission from a 2001 crown athlete and thats how this project began.
169908169909
After test fitting. I knew this was going to be a lot of work. The engine would not fit between the towers in the falcons tiny engine bay. I didn't want to spend a ton on a mustang 2 suspension and so i decided if i notched the shock towers i might have just enough room. I went with the relocation kit from Crites.
169912169910169911
The shock tower kit gave me just enough room. Next it was time for engine mounts. I used factory 1997 turbo supra mounts and brackets and modified the Crites pads to fit.
169913169914
After getting the engine mounts done it was time to address the trans tunnel.
169917169915169916
Pulled the interior out and found more work. The beware of dog sign was covering one of 2 holes in the floor.
169918169919
I will fix that later. on with the tunnel.
I cut out most of the tunnel and made a new one with some 16 gauge. I recently realized that i had a 3" mock up driveshaft and that i needed a 3.5" shaft. I just ordered it and may have to cut it and raise it a little more.
169923169920169924169921169925169922169926 169930169931
Now it was time to build my trans cross member. I also installed a set of Crites subframe connectors.
169934169935169932
[ATTACH=CONFIG]169933
169954
I welded some plate to the floor for strength and then welded some c channel for the cross member to sit in. Then drilled through to bolt everything together. I also tied the cross member mounts to the subframe connectors. Now on to the radiator.
169940169937169938169939
I used a 1991 supra radiator and a spearco intercooler. I modified the lower radiator support and used the factory rubber bushings for the supra radiator.
Then i used a universal intercooler pipe kit and routed the piping. After that i modified and installed the bumper and grill.
[ATTACH=CONFIG]169941169942169943
I still have some fab work left on the bumper but everything fits! I also finished the upper radiator brackets. I used some l brackets and lexus sc400 radiator hold downs.
169944169945
Next i decided to do some floor patching and cleanup. Also got my Aeromotive stealth tank.
169947169948169949169946
169953
I also mounted the gas pedal from a 2001 tundra.
169968
Now it was on to some wiring. I used an is300 fuse block and wired the efi to the factory ecm. I also wired the factory immobilizer circuit and the dlc3 connector. I can communicate with the computer using the factory global Techstream software. i still have to tidy everything up but wanted to make sure everything was functioning properly first.
169950169951169952
So now the engine and trans is mounted, radiator and intercooler done and the wiring roughed in. I decided to build a temporary downpipe for my first start. I used some 2.5" piping and a flange from Driftmotion.com. I don't know if i will use 2.5" or 3" for my exhaust but the flange fit nice and i used a factory downpipe gasket.
169962169961169963 169965
After making my test pipe. I was ready to hear this thing fire up for the first time. I installed the radiator hoses, filled the fluids, grabbed my jump box and after 5 years of sitting, the motor fired right up.
I have a short video at the bottom of this thread.
My goal now is to get the suspension on and figure out how to hook the column shifter to the Toyota trans. I just ordered my driveshaft and some global west upper control arms. I want to get everything together and work the bugs out. Then clean and paint everything and make it look nice. So that's where i am at this point. i will keep updating this as it i make more progress. Thanks for checking out my build!
1jzfalcon
12-05-2019, 01:27 PM
Sorry. Trying to get my pictures to post.
RMMiller
12-05-2019, 07:36 PM
That will be a cool build, good to see a four door getting some love!
1jzfalcon
12-05-2019, 08:41 PM
Thanks! I think this will be a fun cruiser.
slimjim
12-06-2019, 01:40 AM
This is awesome, can't wait to see it burning those tires
Boosted Falcon
12-06-2019, 08:26 AM
What a great project, yours is the second Falcon I have seen with a Toyota inline 6, the other was a NA engine.
RIF RAF
12-06-2019, 09:51 AM
This is great! Should come out as a very fun and reliable car.
3 Years ago I swapped a JDM 2JZ-GTE into an 86 Cutlass after getting rid of the V6. Had it running on a Haltech Elite 2500 and the stock ECU controlling the transmission which was shifted via a B&M ratchet shifter on the floor. I also had to do lots of cutting and modifications to make it fit. Mostly just to the A/C box and crossmember though. I may have gone a little overboard with my install though because I had it looking factory stock in there when it was done.
Depending on how stock you plan to keep it I recommend going to an aftermarket ECU. You're able to eliminate a lot of the "messiness" of the factory wiring, vac lines, etc.
1jzfalcon
12-06-2019, 11:37 AM
Thanks! I love the sound of this engine.
1jzfalcon
12-06-2019, 11:40 AM
I’m gonna keep the power around 400 horsepower. If I upgrade to a top mount turbo later, I may use an aftermarket computer.
andrewb70
12-07-2019, 03:45 PM
Great way to update an old 4 door that most people give very little value to. I really want my next project to be a 4 door.
grambo
12-07-2019, 06:02 PM
That inter cooler mounting is sexy. I so love it. Not a huge 2jz fan, as I prefer the rumble of 8cyl, but they make great power, I am sure you will love it. Now it needs a killer wide body!
jaybee
12-07-2019, 07:33 PM
Cool and different...I like it.
1jzfalcon
Thanks! I can’t wait to load everyone up and ride.
1jzfalcon
12-07-2019, 07:38 PM
Grambo. I love the sound of a v8. My other car is a 5.0 Lexus. This engine sounds amazing at 7500rpm with the turbo screaming.
grambo
12-07-2019, 10:28 PM
I don’t think there is a human who doesn’t like that sound, just some can’t admit it. As for your 2jz falcon, just cause it’s not my cup of tea doesn’t mean I don’t respect it. She’s gonna be a beast. Build on.
1jzfalcon
12-18-2019, 01:22 PM
170490170491
Got my driveshaft in. I am going to have to modify my tunnel slightly. I am thinking about going with the TCI four link.
Boosted Falcon
12-18-2019, 02:33 PM
I have the TCI 4 link along with there front suspension. I am impressed with the fit and install but can't provide impressions on how it drives, in the middle of a 3.5 Ecoboost swap with a ways to go.
1jzfalcon
12-18-2019, 03:02 PM
I know the feeling. So much to do it is overwhelming sometimes. Did it give you more tire clearance?
Boosted Falcon
12-19-2019, 06:18 AM
Yes it does on the front and a little more at the rear. I am going back and forth on minitubbing the rear, I would like to get a 275 on the back. With the measurements I have taken 245 is an easy fit on the front and back with out tubbing the rear.
neongreen
12-20-2019, 08:05 AM
I'm so torn on this. On the one hand I love it. On the other hand I also love it.
I was this close >< to doing a 1JZ or 2JZ in my 62 Falcon. Having previously done an RB20DET ranger swap, I have a great fondness for Japanese turbo inline sixes. Ultimately I went with a 5.0 but half of me still wants a JZ in my car. Anyway, rock on. This is awesome.
1jzfalcon
11-05-2020, 11:11 AM
Haven't updated in a while. Slowly making progress. Got the wheels and tires and the front brake setup installed. Need to make brake and fuel lines and then i can assemble, set ride height and align. I have roller perches and lower control arms from opentracker. Upper control arms are from global west. I also have the opentracker lower camber kit and the adjustable strut rods. Then disassemble again and cleanup and paint the engine compartment and underside.
ryeguy2006a
11-05-2020, 05:27 PM
Very cool project!
