View Full Version : What do you think about this Car/Build?
Michael_
12-04-2019, 05:17 PM
Im in the Market for a 69 Charger Restomod/Pro Touring car right now. (Got a seperate Thread for that)
I found this one:
https://www.hemmings.com/classifieds/x/x/x/2138491.html
While this is not 100% what im looking for its still close enough to be interesting.
But since i am no Car Builder i am having a hard time to judge over the build and price.
I want to use the car as a daily driver in the Summer. (well mainly on the Weekends but should be possible to daily drive)
I want to do Stop and go City Driving as well as long distance driving on the german Autobahn @ at least 110 or better 120mph.
(I live in germany)
What do you think about this car?
Is this a good build?
Is this a fair price? isnt it pretty low given its sold by a dealer? is there a catch?
Rear differential is a posi-trac with what we believe are 3.91 gears. While the sis not the best highway gearing the current owner has certainly cruised down the highway at 70 mph when needed but this set up is really geared up for some amazing stop light to stop light fun and cruising.
Is this a serious issue (because i want to drive 110mph or faster) or can this be addressed
by changing the gear ratio and installing a GV Overdrive?
But even if will the cooling and other components hold up at those speeds?
Also i dont like THIS (particular) blower.
Is this even a supercharger? i dont see a belt or anything.
Can you remove that? how much power would you loose if you do?
Or would it (if not) be at least possible to install something that looks good like this?
https://static1.pt-content.com/images/pt/2019/12/9a66af13fbea4a8aa3169829b5a6b53c-1.jpg
Also the seller promises you can remove that roll cage if you want.
I would want to remove it. That would be pretty important for me.
I have some basic knowledge and what i read like
- Disk Brakes front and Back
- 605 Hemi with 750hp
- Upgraded Suspension/Handling
Sounds pretty good of course but as i am not an expert/car builder i decided to ask here first.
Im not seriously interested in the car at this point.
But if it should be good, i would look into this further and may purchase it.
dhutton
12-04-2019, 05:46 PM
That is not a blower.
NOT A TA
12-04-2019, 08:32 PM
I see overheating issues at high speeds for extended duration. I don't think you'd run it very long at 110-120 MPH before overheating even with a rear gear change. I'd say, keep looking.
Michael_
12-05-2019, 07:16 AM
Thanks for your answers but could maybe someone go a little more in depth?
What is it? Can you remove it? How much power would you loose if you do?
You read that i considered a Gear Vendors Overdrive? Wouldn't that help either?
Why do you see overheating issues, because of unsufficient cooling? Or is the engine itself the problem?
I mean no disrespect with the following:
Do you have a lot of money? If so then no worries.
If not then, with your limited knowledge I have to say that you are better suited with a much milder build, something you can enjoy while you build your knowledge up.
joeko23
12-05-2019, 07:28 AM
As stated before thats not a supercharger. Also if you are looking for a daily driver I would stay away from carbureted cars. Get something with fuel injection. I’m assuming this would be your first classic car? Classic cars require constant fixes,upgrades, changes etc, no matter who built it and how well they built it. This is a hobby for a reason. It’s not a mass produced car so the reliability factor is gone. If you want something that you plan on using daily at least look for something with a modern hemi swap preferably using all original equipment fuel management.
Michael_
12-05-2019, 11:13 AM
What do you mean with "milder" build?
No its not my first classic car but its my first custom car.
Its not that i have absolutely no clue but of course i am no car builder.
Well im not a big fan of modern engines, fuel injection, computers and stuff like that.
I prefer oldschool drivetrains (with carburetors) but i like modern brakes & handling updates and stuff like that. Somewhat best of both worlds i guess. :)
Also i want at least around 500rwhp. (i've also driven faster and slower cars, i think 500 is the right number for me.)
So if someone could explain why this car will have overheating issues that would be great.
not that i dont believe you guys but i would feel better when knowing not only if its good or bad but also WHY.
Michael_
12-05-2019, 08:17 PM
Bump
By milder my main point would be finding one without a naturally aspirated 700hp old school engine. I would also stay away from anything with a roots style blower like the one you showed a pic of. I don't know much about those particular cars but why does it have both leafsprings and coilovers?
minendrews68
12-06-2019, 07:18 AM
The picture in your post and the picture in the "hemmings" ad are two completely different cars. The one in your post has a "root" style blower, the one in the Hemmings ad is nothing more than a carb on a hi-rise manifold.
Michael_
12-06-2019, 11:06 AM
Well i dont need a blower but an oldschool naturally aspirated engine with around 650hp is exactly what i have in mind.
Why not?
Will these engines dont hold up or why do you recommend against it?
You and @NOT A TA recommended against the car i posted.
@NOT A TA thinks it will overheat.
But why? Because of the Engine Design or insufficient cooling/gears?
I mean if you just need better cooling and an Overdrive you can maybe think about that but if the engine itself is the problem thats another story.
As far as overheating, I'll state the more obvious things that I see that are not ideal:
Pusher fans
no fan shroud
nothing to direct airflow from the grill into the radiator instead of everywhere else
Add these items to a radical NA engine & you could very likely have over heating issues
As far as "holding up" that is a pretty broad statement. That engine will need much more maintenance and attention then a more common street car engine. Do you like adjusting valves and tuning carbs?
mikedc
12-06-2019, 05:13 PM
1969 Chargers aren't ideal for cruising at 120 mph for several reasons.
The body itself has terrible aerodynamics. The front end/steering starts feeling lighter from air getting forced down underneath the car. Air rushing past the roof window gutters & front end bodywork is loud. In 1969 Chrysler actually 'fixed' this bodystyle by selling the Charger 500 & Daytona versions for racing. (Those body modifications were combined with having the whole body 'raked' down about 2 degrees in the front.) Going 120 in a stock '69 Charger body is not out of the question but you should be aware that the bodywork is a handicap. You will probably want the body to be raked slightly (as most of these cars are set up by owners now). Some kind of small front air dam below the radiator area might be good too (like the sort of thing that is common on modern vehicles).
The factory 1969 suspension is strong and the handling is predictable. But it's not optimized for modern tires. The steering lacks the centering action of modern vehicles because the front end was built with 0 degrees of caster angle. It could also use an extra 1-2 degrees of negative camber if you are running radial tires. Both issues can be helped with aftermarket upper A-arms and/or offset bushings. The steering gearbox feels a bit more "floaty" compared to a modern vehicle too. That can be addressed with either a rebuilt & tightened steering box or an aftermarket Borgeson replacement.
The factory 1960s brake system is not adequate for 120+ mph in traffic. These cars mostly got drum brakes on all 4 wheels, and that setup is borderline unsafe for 60-70 mph in modern congested traffic. Even the factory optional front discs aren't a great setup (the factory needed them small enough to fit inside 14" wheel rims). If I was going to cruise that fast, I would want some kind of aftermarket 4-wheel disc brake conversion. It's a lot cheaper & safer than getting in a wreck. There are many choices on the market to deal with the brakes, depending on how much stopping power you want to buy and how big your wheel rims are.
Another general comment - it never hurts to stiffen up the body shell on unibody cars like this. US Car Tool Inc makes a whole kit to stiffen up some easy 'problem areas' of these cars. (As in, welding extra bracing onto the undercarriage). Subframe connectors, 'torque box' plating, etc.
Michael_
12-06-2019, 05:44 PM
Well i already knew that and of course you are right.
But i have no intention of going 120 in a Factory Equipped Car.
Thats why i'm also looking for a Restomod, otherwise i would have to do the upgrades myself or pay someone to do them.
Which would likely cost a lot more as i also want 500rwhp.
Basically i opened the Thread because i wanted to know if all these points you stated have been
adressed at the car for sale that i linked in the first post.
Cooling as i now know has NOT been adressed.
Brakes have been adressed as they have been upgraded to disks front and back.
But what about the suspension or even frame reinforcement?
Anyway i think i will not buy this car.
Yeah i get preinstalled Diskbrakes and a 605 Hemi with 750 Horsepower.
But i would still have a lot of work to do (and money to spend) on top of that to make it perfect.
I think i can find something better suited for my needs or if not will be better off to upgrade a Factory Equipped RT myself from Scratch.
Edit:
The Areodynamics from the 69 Charger are not bad at all as the car has been designed with NASCAR in mind.
As far as i know even in the wind tunnel.
Its just the front end from the street cars as you pointed out. the 69 Daytona is basically a upgraded charger that just has better areodynamics (due to different front end & rear wing) and some other improvements.
But im sure you know / meant that.
mikedc
12-07-2019, 07:42 PM
Wind tunnel research didn't start on those Chargers until after the stock '68 models were built and being raced.
The '69 aero models were good, particularly the Daytona. But they were created in response to problems. The stock non-aero 1968/69 Chargers were surprisingly bad.
Michael_
12-08-2019, 01:48 PM
Well i didnt knew that.
I thought the whole car was shaped in a wind tunnel.
But anyway it shouldn't be a huge problem with all the cool aftermarket stuff available these days. :)
A little bit offtopic but what do you guys think about this Chevelle Restomod?
https://www.ebay.com/itm/153748382054
I think it looks pretty good and if it would be a charger i would be very interested in the car.
Aluminum head, forged GM ZZ572 620hp with Dyno sheets available
Hughes Racing TH400 w/3500 stall converter / 1350 U-joints
Moser 9” w/3.70 gears / posi
Custom Lemon’s Headers ($2,000)
Global West tubular control arms and suspension
Dewitt’s 4 core radiator
March serpentine pulleys
Weld Draglites / Moroso fronts / Drag slicks on rear
According to the recipts pictures it also has been converted to Disk brakes.
To me it looks like a very nice car and im a bit surprised nobody bid on it yet?
Well i dont know how good this thing will handle with the Global West Suspension
but if it does well i guess i would just have to upgrade cooling and may install an Overdrive to drive 120mph?
or i am missing something?
NOT A TA
12-08-2019, 05:31 PM
The Chevelle looks like a nice car if you're looking for a cruise night and occasional drag strip car. It's not a car you'll be driving 120 MPH for more than a couple seconds. A 3500 stall converter on the street isn't great for a daily driver and neither are the 3.7 rear gears without an overdrive transmission. Like the Charger you'd need to alter the drive line, wheels/tires, and other things to be able to use it as a daily driver and use it for extended high speed driving.
mikedc
12-09-2019, 10:19 AM
Unfortunately the stock 1968/69 (and 1970) Chargers looked a lot more aerodynamic than they really were.
The 'Charger 500' modifications were bringing the '69 body up to average/decent, at least for pre-1990s cars. They cleaned up the worst-offending spots for air resistance on the body: the grille and the A-pillar covers. The fastback rear window was partly about cornering along with top speed. Tunnel-back rear window designs compromise the downforce at the rear tires.
The 1969 'Daytona' modifications were more applicable to real race cars. They were focusing on balancing the front & rear downforce. Gaining lateral stability with the wing uprights. Using the front fender scoops (above the tires) to let pressurized air out of the engine bay (since the racecars had no inner fender sheetmetal). Etc. This kind of stuff is less important if you just wanna go 100+ mph in a street-car version and you are't trying to corner very hard at those speeds. (Although a Daytona does feel marvelously stable for a 1960s car even at only 100 mph.)
One more little factoid:
There was technically a 1970 "Charger 500." Dodge took the name and applied it to a dress-up trim package for regular 1970 Chargers. It had the standard body (no aero changes). Today it has the value of a normal 1970 Charger, unlike the highly collectible '69 500s and Daytonas.
Michael_
12-09-2019, 12:28 PM
Well i know that this is not a Turn Key Solution and that you have to make some changes.
But i think i will have a hard time finding a turn key solution as there sure are not to many guys out there wanting to drive 120mph for longer periods of time. (And i want an old fashioned drivetrain, no ls swaps and the like)
I think the most important point is how much this chevelle will gonna cost.
Because a lot of work has already been done and a lot of money has already been spend.
And the car seems to look really good.
If you can get it for a decent price than it's maybe cheaper (and less work) to modify this car than building one yourself from scratch.
otherwise its way less attractive of course.
So it depends.
But i think i will pass anyway because i would might regret it as i prefer the looks from a 69 charger. :)
Despite that both cars look cool of course.
@mikedc:
Thanks for the info.
I wish i could afford a daytona but unfortunately that's not the case.
A lot of people seem to find it "ugly" but i think it actually looks pretty cool. :)
And how cool would it be to drive around town or passing people on the autobahn driving 120mph in a late 60s Race Car. :D
Edit:
So you think the Stock 1969 Daytonas can handle 120mph (for longer peroids of time) without changes/upgrades?
Or only the ones that have been raced?
mikedc
12-10-2019, 12:24 PM
@mikedc:
Edit:
The stock Charger 500s & Daytonas were basically standard Charger R/Ts (440 or 426 Hemi) with altered bodywork. They were not mechanically altered under the skin.
Chrysler built the street production 500s & Daytonas (and '70 Plymouth Superbirds) just to make those bodies legal in NASCAR. They lost money on the street legal versions of all the aero cars because of the customizing work. In fact the mass-produced Superbirds came with mandatory vinyl tops in order to avoid the cost of hand-finishing the seams around the rear windows.
The race cars were different animals from the street cars. NASCARs were famously "stock" but by 1969 they were mostly hand-built machines. But unlike today, in 1969 they still used the regular production cars as raw material. They ran stock body shells with rollcages added inside. Stock engine blocks & cranks, with custom pistons & valve sizes & camshafts. Etc. The race cars used the same layout of front torsion bars & rear leaf springs like the street versions, but the spring rates (and ride heights) were all different. Etc.
At 200 mph the heating & cooling & aero demands were getting pretty far removed from regular production cars. The race cars needed fluid pumps & coolers for the rear differential's oil. They adapted bigger wheel bearings onto the suspension. They ran huge non-stock brakes (but still 4-wheel drums!). Etc.
A stock production Daytona, at 120 mph? The aero bodywork would make it more stable/balanced and have lower wind resistance than a regular Charger. The top speed would certainly be much faster. But the street Daytonas did run into engine cooling problems in slower traffic because the nosecone's grille opening was too small (it was just large enough for NASCAR speeds and nothing more). Also, the little reverse-facing fender scoops above the front wheels are mostly useless on a street car. The street car has a higher ride height than the race cars and has full inner fender sheetmetal.
In most ways it's still a stock 1969 Charger. Suspension is tuned for old bias-ply tires on 14" wheel rims, the brakes are not adequate for high speeds, etc.
Michael_
12-10-2019, 03:50 PM
The Chevelle Auction ended today without one single bid which surprised me.
Is there a catch or does really nobody want that car?
https://www.ebay.com/itm/1972-Chevrolet-Chevelle-/153748382054
I contacted the seller and asked what he wants for it.
The OBO Price he responded seems pretty fair to me so i really think about if i should maybe buy it.
I would still have a lot of budget for improvements left.
As far as i see i would have to:
- Add Gear Vendors Overdrive
- Change Stall/Torque Converter
- Change Gear Ratio
- Upgrade Water and Oil Cooling
- Change Wheels and Tires
- Add AC (well thats not needed of course but i would want it)
To daily drive and drive 120mph for longer periods of time.
But that should be it, right?
Of course thats still some work but i guess nothing compared to upgrade a Factory Equipped car?
Other than that the only downside seems to be that it is no 69 charger.
But Chevelles also look cool and this one i think is as nice as a 71-72 chevelle gets. :)
Really difficult decision.
But maybe someone has something to say that makes it easier for me?
Edit:
I just looked at the chevelle description and recipts pictures again.
It looks like the mentioned Global West "Suspension" Upgrades cost just 1500$ and aren't very extensive.
Also it seems that only the front brakes have been upgraded to disks.
Well its still an interesting car because of the phenomenal condition and the zz572 Engine.
But as much as i like the pros of the car i think i should pass anyway.
Because there are a lot of cons (work and money needed to suit MY needs) too.
I think its better for someone who wants the car exactly the way it is.
And finally its not a Charger too.
@mikedc:
Thanks again for your detailed answer.
Well i think you would have to upgrade the cooling anyway, also for "just" 120mph.
But its good to know about those overheating problems in normal traffic.
At the end i cant afford a daytona anyway. But i dont know if i would buy one
(if i had the money) at todays prices. Im not sure if a fancy charger is really worth that much. :)
The Racing Version is of course another Story.
Looked like a nice car but a bolt-on type car with an old school engine is not near as popular as something with a modern drive train and as such the market does not bear big money.
Autobahn-Outlaw
12-15-2019, 11:33 AM
Hi,
i think for longer 120 mph use, you should go with a not so tall rear gear.
And stay away from older style big block engines, they are prone to overheat.
And they will, because it is a lot of metal and the cooling systems are...old style.
My second thought is the frame and brakes. If you do 120mph+ for longer time, you will not feel save. Not to mention the seats, aeros and suspension.
Been there, done that....
For your kind of money, you should really look for a nice protouring car with good brakes, at least 19"wheels with modern tires, good shocks and in a best case an aftermarket frame from AME, Schwartz, Roadstershop or Speedtech.....
And then a modern engine, 500hp are no problem, no H-Zulassung, and best drivable parts.
And most important : have fun !!
There are lots of nice musclecars, not only Chargers...
Michael_
12-17-2019, 04:42 PM
Hi,
I want an Oldschool Drive Train. No modern engine.
But i know i will have to upgrade cooling.
Otherwise i agree with you for the most part.
But i have already seen cars with a modern engine and H Zulassung. :) But i do not want that anyway.
vette427-sbc
12-17-2019, 07:25 PM
You should be looking at a car that is more “pro-touring” than the cars in the links. Cruising a muscle car similar to the Chevelle or Charger you posted at 100+mph will not be fun, or going to last long, or going to be safe. Slapping disc brakes and a gear vendor OD is not going to give you what you want. I think you’d be better off buying one of the many killer cars in the for sale section, and if you must, pull the modern motor and build an old school motor with a modern valvetrain, modern head port designs and a modern cam profile. :grouphug:
In all seriousness, a muscle car that checks off everything on your list and does them reasonably well is going to be a car that was designed and built as a whole.
