View Full Version : A/F jumping at idle
cwylie
12-02-2019, 07:28 AM
Im having an issue with my A/F jumping all over the place at idle. I though it could be an exhaust leak but I am not seeing anything. Could it be a had injector and when this cyl fires it causes a lean spike?
12-15-2019, 05:55 PM
Or a spark plug misfire. It can happen at idle with a lean mixture. Look at your TPS signal stability at idle. If TPS varies, the ECM will react as if the throttle is being opened quickly & add acceleration enrichment.
