View Full Version : 69 Camaro drivshaft Q's
mean buzzen half dozen
11-30-2019, 02:59 PM
Hey guys,
I am shopping for an aluminum driveshaft.
My Camaro will be lower than stock & am wondering what is the largest diameter driveshaft I can run & not rub on the trans tunnel?
My friend had told me if I get too large it will rub on a lowered car.
Thank you
TheJDMan
11-30-2019, 03:56 PM
Already answered your PM but aluminum drive shafts tend to be larger dia than steel. I have a steel 3" shaft. Between the DS and dual exhaust pipes there is not a lot of space in the tunnel. Also, given the proximity of the DS to the exhaust I would be concerned with heat potentially damaging a carbon fiber shaft.
11-30-2019, 08:46 PM
Stock is something like 2 7/8", I've seen 3.5" aluminum used with success, but you have to be sure there are not any long screws protruding into the driveshaft tunnel.
another69
12-01-2019, 08:15 AM
3.5" aluminium works in my 1st gen. Clearance is actually tightest between the Speedtech torque arm crossmember & the driveshaft yoke for me
c4racer2
12-01-2019, 12:09 PM
I have a 3.5” steel. 2nd gen tho.
btmatt
12-01-2019, 12:55 PM
3.5 in 1967 camaro and 3" exhaust. It is very tight
12-01-2019, 05:12 PM
Ok Thx Guys.
Probably order a 3.5"
anguilla1980
12-03-2019, 05:56 PM
I just ordered a 3.5" DynoTech Chromoly DF for my Tremec Magnum and Ford 9". It looks to me like it will be a VERY tight fit but *should* be ok.
12-12-2019, 05:50 PM
No need to go that large unless it’s an aluminum driveshaft.
c4racer2
12-14-2019, 07:35 AM
in my case that was the size needed to mate up with the yoke I bought for the T56. Maybe I don't need such a beefy yoke - but it all fits and it's pretty unlikely to be a failure point down the road now.
12-14-2019, 01:47 PM
I plan on an aluminum driveshaft for weight savings.
