View Full Version : Shelf Life of Tires
7firebird1
11-24-2019, 12:31 PM
I’m just curious on everyone’s experience or knowledge of the shelf life of tires....used and unused. From what I have read the company’s recommendations are replacing after ten years of production. Has anyone experienced any tires failing them from being to old aside from dry rot/cracking?
GoodysGotaCuda
11-24-2019, 01:19 PM
I’ve seen plenty of examples of tires that rotted from the inside out and failed due to age online, but I have not personally experienced it.
I put about 2,000 miles on my 12 year old tires when I first got my car back on the road. Replaced them soon after as I began to drive the car more often.
Unfortunately the failure mode can be catastrophic. I’d mitigate running on old tires as much as possible, they also don’t perform nearly as well as when they are new. Which is important if you plan on slowing down in a hurry.
icemanrd19
11-24-2019, 04:59 PM
6 years shelf life and 10 years use life from date of manufacturing
7firebird1
11-24-2019, 08:33 PM
Thanks Cuda and Iceman! That’s kinda what I was afraid of. I found a pair a unused 335/30/18 BFGOODRICH tires. $325 for the pair...new they were $380 each but these were manufactured in 2014. Probably shouldn’t chance it. Just have to bite the bullet and buy them new just to be safe.
MonzaRacer
01-24-2020, 08:23 PM
If stored inside and not in sun or heat then they would be fine. But price seems bit high.
Tsaints1115
01-25-2020, 08:18 AM
All anyone has to do is google Paul Walker Death and you'll get your answer on the risk of old tires.
Around here (IL) dealers will put new tires on any car they take in trade for resale if the tires are only 5 years old.
mikedc
01-25-2020, 01:42 PM
I swear modern tires are getting worse about coming apart from age than older tires were. Maybe it's a drawback of modern tire compounds/designs.
They can definitely get bad without showing outward signs. That's part of what makes it scary.
Check the 'born on date' that's molded on the tire (google it). Even with new ones. There's no point spending the money for brand-new tires and getting a set that is 3 years old the day you get them.
tm5nardo
01-27-2020, 09:40 PM
My local tire shop won't mount tires that are more than 10 years old.
79 Camaro
01-28-2020, 02:24 PM
The tires on my 98 Wrangler are over ten years old maybe 20,000 miles. Always stored in doors summer and winter. On the out side they look like new. I managed to pick up a nail in one last summer. Took it to my local tie guy to have it repaired and asked him the same question when is time to replace? He said the tires look like new inside and out and not to worry.
icemanrd19
01-28-2020, 08:52 PM
Ive been in the tire business for 13 years and have sold thousands of tires. Again see my comment above. Shelf life is 6 years and usable life is 10 years off of the dot. Your “tire guy” can’t see the molecules of the tire. Tires change from hot and cold cycles. Don’t chance it
TheJDMan
01-28-2020, 09:14 PM
This is from the OSUSC general rules.
"All entrants in the Intermediate or Expert class must have tires with a manufacturer date within five (5) years of the date of the OSUSC event being entered."
badazz81z28
01-29-2020, 04:26 AM
General rules because you never know what type of climates the tires have been exposed to and safety needs to be maximized. The 2 year old tires on the truck in the Las Vegas sun show signs of cracking on the sidewall while the 4 year old tires in the garage on the Camaro still look new. OUSCI has rules, but for your daily driver just use common sense. You can tell if a tire is in bad shape and should not be driven on.
parsonsj
01-29-2020, 06:38 AM
If you are going to take the car to the race track, the guideline is typically 2 years old or newer.
