View Full Version : 1964-65 A Body Rolling Chassis
kochevy67
11-01-2019, 09:07 PM
Chassis that has been narrowed for a minitub. Below are a list of the parts and mods that were done to this frame. Everything on the chassis is brand new with zero miles with the exception of the front Hotchkis suspension and the disc brakes on all 4 corners. I am located in Chicago. I would to get $5000 for everything.
Frame is freshly painted and is not pitted, the frame has a ABC box kit on it and is narrowed. I can get exact measurements for anyone interested.
12 Bolt Moser posi unit with 33 spline axles with 373 gears welded tubes with 9 inch ends
Hotchkis rear upper and lower control arms, tops are double adjustable
Chassis works Anti roll bar
JRI Coil over shocks
Front suspension
Hotchkis upper and lower control arms (coil spring) with B Body spindles
Hotchkis sway bar
Steering linkage painted with steering box from DSE
Disc brakes with 1991 Z28 1LE cross drilled and slotted rotors
Tubular Crossmember for a T56 transmission as well.
I cannot seem to figure out how to post pics, however I will email anyone interested as many as they like. PM me and I will get them out asap.
kochevy67
11-06-2019, 03:33 PM
Am I out of line on the price? any suggestions on how to sell this
dhutton
11-06-2019, 06:22 PM
Pretty small pool of potential buyers for that frame. Try the Chevelle forum.
Don
kochevy67
11-07-2019, 09:35 AM
Don
Im seeing that. I will post it over there
Raffman
11-08-2019, 09:44 AM
There is a FB Chevelle page you might try too....
kochevy67
11-09-2019, 08:04 AM
Thanks will do
