View Full Version : 1968 Camaro: 17x8 tire size recommendation
majj35
10-23-2019, 10:21 PM
Hello, I have a 1968 Camaro Restomod and need to change my tires ASAP. It's a street driven car only. I bought it 5 years ago from an owner who restored it with a 350ci and sold it to a dealership. I don't have any contact with them anymore, and they did not know what parts were used. So I had to do some digging to find out. Last year I did an LS2 build, and now looking to improve handling. (Started another thread for suspension advice CLICK HERE (https://www.pro-touring.com/threads/132555-1968-Camaro-Help-with-Suspension-Setup))
My current wheel setup:
My fronts: 235/45/17
My Rears: 275/40/17
Wheels: 17x8 (4.5 backspacing, 0mm offset)
Suspension
Coil springs: Looks like I have the stock coils with spacers in them
Shocks: KYB Gas-a-just (i know horrible, swapping them next)
Leaf springs: Unknown (looking to go with Hotchkis or RideTech)
I was hoping to get the same setup, however, where I currently am, no one has the 275s and I can't find any shop willing to ship overseas.
My goal: Looks!
Summer street tires
Even out the ride height equally, I don't like the rears being noticeably higher than front
Keep the wide tire look
Wheels to stick out a little, or to be aligned with fender.
Questions: (please consider ride drop if I go with leaf springs 1.5" - 2")
1) What's the closest rear setup I can go with to what I have in the rear?
-someone said 265/50/17
2) Front: Can I go with 245/45/17? (do they do 245/50? - will that even out?)
A few Photos below.
168580168579168578
Thank you very much
eville
10-23-2019, 10:40 PM
This is a 255/50/17 in the back. It’s too much tire imo.
<img src="https://i.hmjimg.com/images/2019/10/23/82120D88-C7C8-4441-AD71-9FD7BEB0CAFD.jpg" alt="82120D88-C7C8-4441-AD71-9FD7BEB0CAFD.jpg" border="0" />
Consider 18s. 275/35/18 rear 245 front. I’d do a 275/40 rear next time.
<img src="https://i.hmjimg.com/images/2019/08/28/BD90910E-E237-4A34-A52F-AF1FF1EC16AF.jpg" alt="BD90910E-E237-4A34-A52F-AF1FF1EC16AF.jpg" border="0" />
majj35
10-23-2019, 10:44 PM
Hi Steve, thanks for sharing. I just got my AR wheels, and a little tight on budget. So i'm going to have to stick with that for a while.
255/50 too much tire? you mean because it's too thick?
I can't find 275s where I am in KSA. Checked everywhere.
eville
10-23-2019, 10:46 PM
255/50 is huge and fills the wheel well too much it looks weird.
majj35
10-24-2019, 12:17 AM
What else can i go with as long as the wheels stick out the wells a little?
What about wheel spacers? Any recommendations on brands and mm to go with?
68Formula
10-24-2019, 04:46 AM
I disagree that 255/50 looks like too much tire, but to each their own.
As for the 245/50:
1) It won't look right on the wheel arches of the front (on a 1st Gen, the front arches are tighter radius than the rear, so you can get away with a larger rear diameter wheel/tire combination).
2) That tall will probably contact the rear portion of the front fender during a turn.
3) I haven't heard anyone have luck with fitting a 245 on a 0 offset rim with a stock subframe. Usually 235 if max.
majj35
10-24-2019, 05:06 AM
As for the 245/50:
Ill be getting adjustable coilovers as well.
So for fronts, better to stick with 235/45 then. Can i add any wheel spacers?
For the rears? What’s the closest to 275/40, i can go with?
Thank you
eville
10-24-2019, 08:53 AM
you're battling a problem that the backspace is wrong. You can put a smaller tire width, but the backspace of the wheel is wrong. A spacer will only push a the wheel out further which is only making your problem worse.
The options are:
Narrow the rear end
Buy wheels with correct backspace
or, leave the rear end up high enough that the tire won't interfere with the quarter panel.
You want to lower your car in the back, a 255/50 is 27" in diameter, your 275/40 is 25.7" in diameter. The 255/50 will raise the back of hour car about 5/8 of an inch. 26" diameter tires are what look best on a 68 imo
majj35
10-25-2019, 01:58 AM
So whats the closest tire setup to 275/40 i can go with? Keeping the same wheels
Thank you
68Formula
10-25-2019, 04:07 AM
Thank you
Not exactly clear what you're trying to accomplish. But if it's a tire height match to the 235/45 (which you can't change unless you change the wheel backspacing) and still wider, then it'd be a 265/40. That will gain you 5mm clearance to the fender, and possibly make up for the incorrect offset of the wheels. I'm surprised you're only running an 8" rim in the back with the 275s now, considering they recommend at least a 9" rim for that.
majj35
10-26-2019, 09:39 PM
I've finally found someone who can ship internationally, TireRack. I found the same size setup as I currently have so might stick with that. Still digging for answers
majj35
10-28-2019, 03:40 AM
Hey guys. Sorry last advice before I place an order.
Which REAR tire size to go with. Wheels are: 17x8 , 4.5b/s, 0mm offset
Keeping fronts the same: 235/45/17
Rear Tire options (with adding RideTech 2" drop springs front & all shocks Streer Performance):
1) 255/40/17 (NT555 G2 or BF G force)
2) 255/45/17 (NT555 G2 or BF G force)
3) 265/40/17 (Bridgestone Potenza)
again, goal to even out ride height as much as possible without having the rears noticeably higher than front.
This is how my car sits now (stock springs, KYB shocks 235/45 & 275/40)
Much Appreciated!
stab6902
10-28-2019, 04:13 AM
A couple of points to consider:
- 255/40R17 rears would be shorter (smaller outside diameter) than the 235/45R17's you're putting on the front. In my opinion rear tires should never be shorter than fronts; it just doesn't look right, even if they are a little wider.
- 265/40R17 are hard to find and and still suggested for a 9"+ wide rim, but they're closer to being OK than a 275. They're exactly the same height as the fronts. This site is your friend for comparing tire sizes: https://tiresize.com/comparison/
- Tires are like shoes - even if they have the same size printed on them, some brands run bigger/wider than others. Those Sumitomo's you have on there appear to run on the small side.
What about running a 45 series tire on the rear as well? The conservative sizing approach would be 245/45R17, and that's what I'd do if I were in your situation. That'll be a little taller and a little wider than the fronts, be the perfect size for your 8" wheels, and probably allow you to lower the rear a little more without rubbing. The Sumitomo's you have aren't the best, so it won't be hard to get equal or better grip from a 245 wide tire if you choose wisely.
Edit: Just saw you were considering 255/45R17 as well. That would be a good option too, but that's an uncommon size so you won't have many tire choices.
majj35
10-28-2019, 04:19 AM
Thanks Ryan. I see what you mean. for the 245/45 in the rear .. you think the width will be very noticeable?(looking at the car from the back) since it's street driven, here, I care about it looking more "agressive" with wide rear tires.
Anyone running that rear 245/45/17 setup? would love to see photos on how it looks on 17s.
anyhow, I'll consider 245/45 and see if Nitto of BFG have them available. If not, which other brands are recommended? Summer/Street.
Thanks again
68Formula
10-28-2019, 04:22 AM
Agree with the above. The 255/45 is more appropriate for the rim width, and at least more common than the 265/40.
majj35
10-28-2019, 04:37 AM
Here's what brands I found that make the sizes based on your size suggestions. Only Q if there's availability. I will check locally & abroad.
For 245/4517 , 255/45/17 (Nitto 555 G2, BF Gforce comp2, Toyo Extensa HP II, Continental Extreme Contact)
For 265/40, only Bridgestone Potenza & Mich Ps
as much as I'd prefer wider, I think my best option is the 255/45. I hope I find them. Thank you all so much
stab6902
10-28-2019, 04:38 AM
Here's a 68 with 235/45R17 front and 245/45R17 rear: https://www.southernmotors.com/Inventory/Details/3909
Here's a 67 with 245/45R17 front and rear: http://blog.rickscamaros.com/1967-camaro-rs-queen-camaros/
245/45R17 rears on this one too: https://www.streetsideclassics.com/vehicles/1755-dfw/1968-chevrolet-camaro
There's nothing wrong with 255/45R17's either if they come in a brand you like. Sounds like you'll be ordering tires from overseas regardless, so local availability may not be a factor.
majj35
10-28-2019, 05:21 AM
Exactly what im looking to see thank you very much!
majj35
10-29-2019, 07:10 AM
Anyone ever heard of Nitto 5g2a?? That’s what one local shop has
Also, michelin Primacy 4. (Dont know that either)
...still searching for 555s
JuanaAlbers
11-18-2019, 02:28 AM
You must always check different sellers to choose the best. I recommend that all sellers' personal materials be checked here https://newyorkessays.com/plagiarism-checker/ for plagiarism to identify fraudsters.
