anguilla1980
09-30-2019, 07:48 PM
On my 69 Firebird, I just completed a total suspension and rear end upgrade. Literally every part Hotchkis makes for it (less the handle bars because of my A/C compressor) plus a couple of things from Global West (solid body drop mounts and spherical leaf bushings). I also upgraded my 14" Rally IIs to 17" look-a-likes.
I took it to get an alignment this morning from my usual guy and that went ok. On my way there I noticed the steering was really hard on center, figured after the alignment it would be just as before.
Well, it's not.
Basically, the steering feels VERY heavy when going straight and is a tiny bit of a handful to keep going straight because of this. The moment it goes off center either way she wants to turn like a pro.
I made sure to tighten everything with the front suspension loaded of course but maybe something is too tight? Could sway bar end links being too tight cause this issue?
I'm not sure what is the cause, everything seems to articulate perfectly with zero squeaks or sounds. I thought maybe my power steering pump went South from the car being parked for 3-4 months even though it's only a couple years old and I did notice it was a tiny bit low on fluid. I sucked some out and added Lucas power steering treatment and went for a test drive. Same issue.
I drove the car for about 10-15 miles on some fairly rough pavement thinking maybe something needed to settle. No change.
Any ideas?
Thanks!!!!
Well, it's not.
Any ideas?
Thanks!!!!
