View Full Version : Pro-Touring F-Body GT front springs (LS/Small Block Specific)
F-Body International
09-22-2019, 06:05 AM
Pair of PTFB GT springs. Never installed.
I had this set up for an iron engine LS but it'll work for SBC as well. Should be about a 2" lowering spring.
Only reason for selling is that I got the original engine from my car back and I'm going to switch the car back to that setup. I'm switching to a heavier spring from PTFB.
These go for $169............I'll $120 shipped
http://pro-touringf-body.com/Suspension_kits.html
bsting
09-24-2019, 02:54 PM
Hey, so will these work on SB350 With AC and will the ride still be 2" lower without spring cut?
09-24-2019, 03:36 PM
I don’t know where your car sits right now. There are too many factors for variations for me to give you a guarantee. With AC you should be getting as low as possible with your given engine combination. Aluminum heads can make your car sit higher. Low-friction control arm bushings will allow your car to sit as low as possible. PTFB also sells adjustable body mounts can lower your car 1/2” without even changing the spring. Another way to lower your car 1/2” without changing springs is using 1/2” extended ball joints. Spring spacers can raise your car. Many manipulations can be made.
68Formula
09-24-2019, 04:38 PM
What the rate?
09-24-2019, 06:11 PM
What the rate?
Should be 500-600lb range. Most of the sponsors on this forum fall on that range for LS/SBC lowering springs. This is not listed on their website.
I know with small block, for example, DSE lists 550lb and Hotchkis lists at 600lb. These should be right about there.
ryeguy2006a
09-25-2019, 04:29 AM
I ran these springs in my car with my LS swap and this is what mine looked like uncut.
https://static1.pt-content.com/images/pt/2019/09/26957053884_f222f03f5e_b-1.jpg
09-25-2019, 01:22 PM
Thanks for sharing ryeguy! Looks good. Always going to miss seeing the ‘76 on the forums. Maybe one day you’ll have another chance at buying it back.
Still available.
10-01-2019, 11:00 AM
Sold
