View Full Version : 67 Firebird 400 - LS2/TR6060 Ridetech - $43,500
rickpaw
09-12-2019, 10:43 AM
I'm testing the market to see if I can sell the Firebird and move on something different.
The car is a true 400/400 Firebird, with deluxe interior. Original motor/tranny were long gone when I acquired it. Did a frame off restoration on it in 2009/2010.
Body:
-Quarters/trunk pan replaced. Patch panel on the rear driver floor board.
-Frame off restoration with new or refinished hardware.
-Subframe connectors/DSE 4 point roll cage.
-Fiberglass Trans Am hood
-Speedtech solid body bushings.
Mechanical:
-LS2/TR6060 swap. LS2 has about 1k since rebuilt and has a small Cam Motion cam, upgraded to bronze rocker bushing, new oil pump/timing chain/front/rear seals. 243 heads rebuilt with PaC springs/titanium retainers.
-TR6060 is stock 80k drop out from a 5th gen and new (less than 1k miles) LS7 clutch/flywheel, and new GM slave. MGW shifter with adapters to mount the shifter directly to the tail housing (got rid of the stock remote shifter)
-58x with LS3 throttle body.
-McCleod manual conversion with wilwood m/c.
-Holley Dominator EFI set up.
Interior:
-Mostly stock with Recaro Specialist seats, recovered stock rear bench.
-VHX gauges with GPS module. Speedhuts gauges for oil temp/fuel pressure.
-5th gen console
-Vintage Air AC
-6 speaker stereo, with subwoofer/Alpine amps
-New AAW wiring harness. LED tail lights/halogen headlights running thru relays.
-Front 3-point Morris seatbelts, stock lap belts rear
-Fully lined with Dynamat/Dynaliner
Suspension:
-SPC front upper/lower control arms.
-Ridetech 4-link rear.
-Ridetech single adjustable coil overs front/rear.
-Speetech AFX tall spindle
Wheels/Brakes:
-Front: Wiwood Aero6 calipers with C6 Z51 DBA rotors
-Rear: stock 4th gen rear discs with working parking brakes.
-Wiwood 1" mc with 9" dual diaphram booster
-Formula 43 3-piece wheels: 18x8.5 front/ 18x9 rear. 245/45/18 tires front; 275/35/18 rears
Car is a driver, with paint chips here and there. It's been on PowerTours; Cruisin the Coast, and participated in Optima challenge and LS Fest.
Asking $43,500 or reasonable offer. Car is located in Houston Tx. Clear title in my name.
https://static1.pt-content.com/images/pt/2019/09/48723245017_ebf2dc670f_z-1.jpg (https://flic.kr/p/2hevnfz)IMG_1477 (https://flic.kr/p/2hevnfz) by Tu Ho (https://www.flickr.com/photos/137989039@N03/), on Flickr
https://static1.pt-content.com/images/pt/2019/09/48723245062_7b6db41582_z-1.jpg (https://flic.kr/p/2hevngm)IMG_1476 (https://flic.kr/p/2hevngm) by Tu Ho (https://www.flickr.com/photos/137989039@N03/), on Flickr
https://static1.pt-content.com/images/pt/2019/09/48722735818_2213d604a7_z-1.jpg (https://flic.kr/p/2hesKTh)58984850590__FA95E872-4CBC-47C8-8F59-71FE4B1B3210 (https://flic.kr/p/2hesKTh) by Tu Ho (https://www.flickr.com/photos/137989039@N03/), on Flickr
https://static1.pt-content.com/images/pt/2019/09/48723069696_96291eb2cf_z-1.jpg (https://flic.kr/p/2heut8N)IMG_1479 (https://flic.kr/p/2heut8N) by Tu Ho (https://www.flickr.com/photos/137989039@N03/), on Flickr
rickpaw
09-30-2019, 11:02 AM
Bump.
rickpaw
10-18-2019, 03:47 AM
Bump.
ryeguy2006a
10-24-2019, 07:19 AM
Those Recaro seats look great in there. What are they out of?
rickpaw
10-25-2019, 07:15 AM
Ryan, those are Recaro Specialist (universal fit).
