View Full Version : Electric Brakes
Hemi8
09-04-2019, 02:54 PM
Anyone install electric brakes, do you recommend? I have a manual brake setup only because there is no room under the hood for hydro or vacuum boosted.
http://www.abspowerbrake.com/ehpm.html
Mike
andrewb70
09-04-2019, 04:30 PM
Looks interesting, but I have no direct experience.
a67
09-04-2019, 05:27 PM
The '86 - '87 Turbo GM g-body cars ran the PowerMaster systems. Along with some GM diesel cars.
They did work well, but needed a lot of maintenance. Regular brake fluid changes are mandatory as the fluid ran through the electric boost motor. Along with the pressure reserve ball.
GM did eventually did give up on the system as the maintenance was too high and failures were often.
If you do go with it, it would be helpful to know how it works out.
Bob.
WallaceMFG
09-04-2019, 07:18 PM
I know a guy that has the ABS system in his car. Mark Allen is frequently at the Good Guys AutoX in AZ, he has one in his blue 68 Camaro. He has said nothing but good things about it.
Only thing I don't know is if they have different sizes of master cylinders or not. Would have to call and ask about that.
Hemi8
09-05-2019, 02:07 PM
Yes mine used to have the powermaster but it only works with the stock brakes, I'm way past stock, C5 in front and Baer's in the rear so there is a lot of volume to push and I just do not like manual brakes.
167203
Mike
