View Full Version : Holley LS engine mount, Total Height Installed.
indyjps
09-02-2019, 03:19 AM
Looking for total stack height of Holley LS engine mount kit, engine bracket and clamshell mount. Measurement from subframe mounting surface to engine mounting surface.
Was looking at this thread and this pic
https://www.pro-touring.com/threads/82832-What-are-the-simplest-%28-LS-%29-motor-mounts-for-1969-camaro-and-where-should-i-buy-the/page3
Trying to get my engine set down low in the chassis for hood clearance and T56 clearance.
69 camaro, stock suspension layout with upgraded parts, LY6 with truck accesories. I will cut the subframe for clearance is needed. Undecided on oil pan, probably Holley.
167105
130fe
09-02-2019, 03:47 AM
I have the exact same setup you pictured in my 68. Running a T56 magnum and stock flat style hood. No modifying the trans tunnel and plenty of clearance everywhere. I would definitely use the -2 or -3 pan if you are going to the other Holley parts.
andrewb70
09-02-2019, 10:20 AM
I believe the only pan that works with the 1st gen f-body Holley mounts is the 302-1. Double check with the Holley website!
Toddoky
09-02-2019, 11:13 AM
The Holley 302-2 and 302-3 pans are the ones that are usable with the Hooker Blackheart 1st-gen F-Body LS swap system components.
indyjps
09-02-2019, 02:56 PM
Great feedback guys, car pictured is not mine, Toddoky posted it.
Does anyone have their car apart enough to get a measurement on the total installed height of the Holley mount from subframe mounting surface to engine mounting surface.
Im considering going a different route on the mounts to get the engine lower in the chassis. Can anyone comment if I use the Holley 302-2 pan - What engine clearance issues Id run into with a half inch or more lower engine placement.
Subframe I can notch, suspension components not so much.
Headers I understand will be an issue, I dont mind chopping them.
indyjps
09-02-2019, 02:59 PM
I have the exact same setup you pictured in my 68. Running a T56 magnum and stock flat style hood. No modifying the trans tunnel and plenty of clearance everywhere. I would definitely use the -2 or -3 pan if you are going to the other Holley parts.130fe, what accessory drive are you running? I dont know what type is in the picture.
130fe
09-02-2019, 03:44 PM
Indy, I have their mid mount system and all of the other newest version Holley mounts and headers. The picture you posted looks like a vintage Air front runner system I think. Either way there are very close ones n dimensions but I think the mid mount is better with the newer style alternator and C7 water pump (cartridge style). I am sure Todd (Toddoky) can give you an idea of the stack height. He has been a great help on the boards for a lot of the Holley stuff. Thanks Todd!
Just curious on why you are trying to lower it, trying to put an LSA or something similar in?
I can’t give you a measurement though right now. I am out of town for the next couple of weeks.
indyjps
09-02-2019, 05:20 PM
Looking to use truck intake with 69 stock height cowl hood. This will get me 49lb injectors when I swap to L96 Flex Fuel's, to support .600 or so cam and power requirements. Likely hone throttle bore and remove inner gussets on a spare truck intake. Not too concerned on appearance between truck intake and LS3 intake. I keep the hood closed from years of street racing. May go with L76 intake if necessary, clip style map sensor.
If I need to buy a complete accessory drive and complete Holley install kit - my budget is gone, see ya next year.
I dont mind cutting the floor if needed, yes i know everything is supposed to clear with Holley system, but would prefer not to. I shot the bottom of the car with gravitex and urethane on a rotisserie and no longer have the rotisserie.
Im considering using factory big block mounts with short wide poly mounts and swap plates. Would like to compare the stack height of the Holley mounts to this combo. I dont mind fixturing and welding up shorter frame stands if needed.
I like that the factory big block mounts shift the location to the passenger side compares to sbc.
If someone has a 302-2 holley pan with holley mounts, how much clearance is there to go lower in the chassis, whats going to hit first.
Not concerned with sectioning and welding on the subframe for clearance, Ive owned the car for 28 years as a driver and drag car, there plenty of other permanent welded mods.
Toddoky
09-03-2019, 11:24 AM
I was able to scrounge up the parts for that Hooker Blackheart engine bracket/mount assembly and measure its stacked height for you...it's 3.5".
John McIntire
09-03-2019, 12:22 PM
I have this setup as well, but wanted to add that the Mast oil pan will supposedly clear. It's what I plan on running since I have an LS7 and need the clearance for the longer stroke. Mast says it will, and Hot Rod Magazine used it in their Crusher Camaro when they swapped in an LS7, I think it was during PRI? They used everything Holley and it fit no problem.
Toddoky
09-03-2019, 01:17 PM
Hey John, I can give you a little further insight on this as I was at the PRI Show that year helping them with getting the engine swapped into the car. The main engine crossmember in the car was deeply notched to clear the oil pan on a previous engine swap, so you're not being provided with a clear picture of fitment by the fact the engine was equipped with a Mast pan.
I'm not sure if you are aware of it, but the Holley 302-3 oil pan will clear a 4" stroke crank also.
John McIntire
09-04-2019, 08:59 AM
Oh, I did not know that you were involved with that. Do you work for Holley?
I did call Mast and they did say it would fit, but I'd rather stick with all Holley stuff since I know it was designed to work together. I didn't know they had a pan to clear the 4" stroke of the LS7.
Toddoky
09-04-2019, 11:02 AM
Yes, I'm a design engineer at Holley and my primary responsibility is the development of the Hooker Blackheart engine swap systems, which now includes LS, LT, Coyote and Gen 3 Hemi applications. The 302-2 Holley pan was designed to offer a few more features than the 302-2 pan (i.e. clearance for a 4" stroke crankshaft and turbo drain back ports) and also better fitment in a few applications due to the chamfered front corners of its sump.
rallystyle
09-04-2019, 09:18 PM
I have a mast pan in my camaro with the Holley setup. -2 pan did not clear my tru turn set up. Mast pan has no problem. My set up is the old tru turn.
indyjps
09-05-2019, 02:04 AM
I was able to scrounge up the parts for that Hooker Blackheart engine bracket/mount assembly and measure its stacked height for you...it's 3.5".Awesome. I still looking at them. Would prefer to use these.
indyjps
09-05-2019, 02:14 AM
Toddoky,
Any feedback on how badly a gen 4 truck low mount compressor interferes with the subframe or steering components. Hooker Blackheart install pdf says the mounts will not work with low mount.
If a low mount a/c takes a subframe notch I can live with that, if it sits in the middle of the sway bay, thats an issue I dont want to tackle.
I did see the Holley / Hooker high mount a/c conversion bracket. Looking into it more.
Im an Engr too, havent designed for some time, pulled into operations, purchasing, quality mgr. I hope you understand my need to thoroughly review all options based on my build criteria. :-) Really appreciate your assistance.
Toddoky
09-05-2019, 03:23 AM
I will take a look through my file photos to see if I have anything that will help answer your question on the stock truck compressor. I understand your need for information, which is why I show up on the forums I am on to post it up.
Toddoky
09-05-2019, 07:06 AM
You have a few options for accommodating the A/C compressor mounting when using the Hooker Blackheart engine mounting brackets, but using the stock A/C truck compressor is not one of them due to the cantilevered design nature of the engine mounting brackets. If you stick with the truck FEAD system, you can use the Holley top mount A/C relocation bracket, or you may also be able to use the Holley low-mount A/C compressor mounting bracket for the Sanden SD7B10 compressor. The clearance of the low-mount set-up installed at the truck FEAD spacing has been verified to clear the Hooker Blackheart engine mounting bracket in a CAD model scenario, but the clearance of the assembly to the anti-sway bar has not been checked on a vehicle at this point in time. This two images depict the fitment envelope of the Holley low-mount A/C compressor bracket. 167192167193
John McIntire
09-07-2019, 05:39 AM
Toddoky,
You have a PM!
Thanks!
indyjps
09-09-2019, 04:10 AM
This is so helpful. Thank You.
Holley 302-3 pan is on order. L76 intake is on the way, looking at idler pulley relocation options.
Will swap the pan, mock up front suspension, and do some test fits with truck AC mount, see what happens.
What firewall clearance is typical with Blackheart mounts?
Toddoky
09-09-2019, 06:46 AM
I don't have a discrete reference measurement that I can provide you with in terms of the distance from the firewall as I never measured it during the development process. I can however tell you that the Hooker Blackheart mounts do not cram the engine up against the firewall like the use of common 1" set-back swap plates do, and also to not move the engine forward by a questionable amount like some other mounting brackets I've seen that do. As a reference, the mounting positioned obtained allows the use of the stock A/C evaporator case for those wanting to use it, and also positions the shifter of a T56 Magnum transmission up through the stock shifter cut out in the tunnel sheet metal. The appearance of this positioning looks very natural and factory-like...here's an image of an LS installed in a 69 Camaro using the Hooker Blackheart engine and transmission mounting components for you to get a look at.
167322
