View Full Version : Anti Sway bar bushing grease?
pitts64
08-29-2019, 04:46 AM
I am installing a new Hellwig 55703 bar on my 69 el Camino today. Can I use regular Kendall wheel bearing grease to lube the bushings?
Any pointers on the sway bar install would be appreciated..
Thank you..
Schwartz Performance
08-29-2019, 06:16 PM
Polyurethane grease is a must
https://www.summitracing.com/parts/ens-9-11110
-Dale
Build-It-Break-It
09-01-2019, 06:26 AM
The one Dale posted will work. I always use Magic Lube that comes in a tube. It's made to lube pool o rings but has the same chemical make up as the energy suspension brand.
For around $5 you can get it at your local pool supply and in the reusable tube for future use.
pitts64
09-01-2019, 08:07 AM
Thanks for the tip!!!
Is this it?
Build-It-Break-It
09-01-2019, 08:12 AM
Yep that's the one. Better price for more product and does the same thing in a reusable tube.
Make sure you wear gloves when your using it. This type of grease is sticky and hard to take off. That's the"magic" of the grease. It doesn't wash off easy with water and sticks to were you apply it.
pitts64
09-01-2019, 08:20 AM
Thanks!!!! I'll check my supply house for a better deal.. E-bay has it for 5 a tube..
https://www.ebay.com/itm/MAGIC-LUBE-TEFLON-LUBRICANT-SEALANT-1-Oz-Pool-Pump-Filter-Oring-Gasket-Lube/283450714695
167092
