View Full Version : Wheel/tire help
DJW32
12-13-2005, 03:54 PM
I need a beat up factory set of 17" rims/tires that will fit the 67 camaro. This set will be used while I take the car from place to place. I need 17's because the car will be receiving bigger brakes, UCA, LCA, and mini tub. Will rims/tires from a 98-02 camaro fit? Will the 93-97 fit? :dunno:
Thanks for the help, David
FYI: The final set of rims will be 18's all the way around :yeah:
Ralph LoGrasso
12-13-2005, 08:40 PM
93-02 F-body rims will fit, with some spacers. You'll want either SS or WS6 wheels, as the Z/28s came with 16s and I think the T/As did too.
DJW32
12-14-2005, 02:27 PM
Ralph,
what is your best guess for the spacer size
Ralph LoGrasso
12-14-2005, 02:38 PM
David,
Probably around 1.5-2" or so, but I'm not entirely sure. You'd need one of those "adapter" type spacers, though. Do a search if you can, as the spacing may have been covered in a past thread.
ilovefirstgens
12-14-2005, 09:36 PM
Well if its just for moving around why not find some spares from a car that had big brakes stock, wouldnt haveto bother with the backspacing and much cheaper
DJW32
12-15-2005, 09:00 AM
ilovefirstgens,
thanks, I will look into that.
