View Full Version : 69 1st gen anyone have more than 8" width in front wheel
indyjps
12-13-2005, 03:05 PM
checked out the wheel database, has anyone been able to run more than an 8" width 17" wheel on the front of a 69. talking about cars with stock subframe. also how much width will aftermarket a arms gain. was going to use aftermarket uppers with stock lowers will aftermarket lowers help wheel clearance significantly.
Johnny Blaze
12-13-2005, 04:47 PM
I'd like to hear this one too.
12-13-2005, 05:24 PM
do a search cause Carl C is running wider than 8".
indyjps
12-13-2005, 09:14 PM
just checked CARLC's website and he lists 17X9.5 5.5 b/s for wheels front rear, does anyone know what his upper an lower a arms are. if they are stock or aftermarket.
DanT69
12-13-2005, 10:20 PM
I believe that his car is in the Jan. 2006 Chevy High Performance, according to them he is running speedtech performance tubular control arms with the gulstrand mod.
vanzuuk1
12-14-2005, 03:56 AM
Are the wheelwells exactly the same from 67/68 to 69? I will check this out and get back to you guys.
Johnny Blaze
12-14-2005, 04:53 AM
If anything, I would think 67-68 would have a bit more clearence on the outer fender lip area.
MarkM66
12-14-2005, 05:45 AM
Gotta run short steering arms to clear 5.5" bs!
baz67
12-14-2005, 08:24 AM
I have 8.5 with a 5.125 BS
indyjps
12-14-2005, 11:40 PM
thanks for the help everyone, all carlc's info is on his page, i read tot he bottom and saw he was running aftermarket a arms, thanks for the tip on the short steering arms.
Garymac69
12-15-2005, 09:19 AM
I previously had 17x9" on the front, now I have 18x9" with 5.125" B.S. Heidt's tubular arms w/ Guldtrand mod, lowered 2". I had to limit turning radius a little to prevent rubbing the rim on the control arm at full lock. I have stock steering arms.
Gary
yellowrallys
12-18-2005, 10:39 PM
Gary, what size tire did you have on them 17x9s ?
Garymac69
12-19-2005, 09:49 AM
I had 255/40/17
