View Full Version : oil sensor?
kman67rsss
09-22-2004, 03:55 PM
i have an autometer electrical oil guage, and im confused as to where the sensor/sending unit mounts. any help. thanks
rockdogz
09-22-2004, 04:12 PM
I was just working on this - mounted mine behind the distributor right next to where the trans mounts up (big block, not sure if small block is different).
kman67rsss
09-22-2004, 05:06 PM
is there a port there? i'll have to look in the morning.
boodlefoof
09-22-2004, 07:12 PM
I put mine (small block) on the port by the distributer. I had a little trouble clearing the intake and distributor though (that sender is kinda big) and I had to use a little brass extension fitting to get it positioned right. Works great though.
rockdogz
09-22-2004, 09:30 PM
update - I may use the port low on the driver's side of the block in the front. Depends on which one fits better - I'll probably have to drop the engine back in the car with the headers so I can check the clearance.
