View Full Version : Resurface an used ls7 flywheel?
oakhill510
08-21-2019, 07:26 PM
Is it necessary to to resurface a 12k mile flywheel? I bought it off of ebay.
badazz81z28
08-22-2019, 03:03 AM
I personally wouldn’t use it as is, unless you are using the clutch and pressure plate that was assembled with it. With a new clutch, it’s necessary to ensure proper “bedding” AND it’s such a task to dig back in there if you need to. It’s worth the $50 to have it machined down and flat. There are garage mechanic tips to simply scuff the surface.
Chad-1stGen
08-23-2019, 01:56 PM
There is also quite a bit of uneven heat spotting on that. I think my LS7 flywheel looked better after 40k miles of non stop autocross and track days than that.
minendrews68
08-24-2019, 06:34 AM
I would say definitely, yes. I wouldn't take the chance of something going wrong and having to take everything back apart to do it later.
