View Full Version : 1972 Pro tour Chevelle
BretW
08-16-2019, 08:24 AM
Just picked up this project yesterday, and an incredible amount of work and engineering has already been put into it. Its a 72, with a 70 front end. I wish I would of had the additional funds to buy the engine and trans with it, but I bought it as a roller. The frame has been boxed, and a chicane mod done on front. It has hydroboost brake set up with Camaro ZL1 6 piston 14" rotors up front and 4 piston 14" rotors in back. It has ridetech 3 way adjustable coil overs at all for corners, ridetech spindles, and ridetech strong arm lower arms and SPC upper. The real feat of engineering is at the rear, it has a 2013 ZL1 independent suspension grafted in. There was not room for the shock spings to fit without notching the factory frame, so a custom built cantilever set up is in trunk with shocks mounted horizontally. Here are a few pictures of the car in its present state and the mods that have been done.166613166614166615166616166617
raustinss
08-16-2019, 10:17 AM
I've tossed some thought into a irs ... quite cool
BretW
08-16-2019, 10:23 AM
There was a lot of thought that went into the IRS engineering. The cradle unbolts just like on the ZR1. To change ride height, you use different thickness mounting spacers to move it up or down without changing axle and arm angles. There is about 1 1/2 more available to lower rear of car.
