View Full Version : Best c4 Corvette to build for pro touring?
Brizzle08
08-10-2019, 04:29 PM
Hello, I have been looking into some of the cheaper c4 Vette's 91-96 and was wondering what year would be a good year to start a build? I've noticed that the manuals are harder to find at a reasonable price the newer they get and the LT4s also seem to be out of the question for my price range. I see allot of autos going cheap in those years but just looking for some input. Hoping to so some suspension, brakes, motor/tranny work, etc. But not sure what year and model would be the best start for the cheaper c4's. Thank you!
Dliccardi
08-10-2019, 07:35 PM
The C4 is plenty capable but here are some things to look for.
If you are holding to the 91-96 stick to the 91-95 unless you are getting the lt4 car (Grand Sport). You will just be increasing your price for not much value.
For suspension: If I was looking I would be going for the 91, 6 speed with the option code “Z07”. The spring rate and sway bar setup was pretty good. I just never found the automatic, or the softer suspension much fun. A hollow front bar with adjustable links is a good setup. Make sure the shocks are in good shape and unless absolutely needed don’t worry about the adjustable suspension, not much value. If the bushings are not rotted you will be pretty good with them (Z07 option), if they are put poly in.
Brakes: Good pads are typically all that is needed unless you track the car. If you do, you will fade fairly quick, so rotors or aftermarket brakes may be needed.
Engine/trans: 6 speed. Engine takes the typical bolt ons and outside of the optispark they are pretty bulletproof.
These cars are little go carts if you get the right options, it’s more the maintenance side that matters. And just an FYI, the mechanical side is bullet proof, the interiors are built poorly with cheap materials.
c4racer2
08-11-2019, 06:07 AM
I built a 91 into a track car many years ago. It was a z07 car. Worked pretty well with that setup. I used the ZF 6 speed that came with it and built a hot rod gen 1 sbc with aftermarket efi.
Really you can start with any 88-96 manual as a start point. You would think auto car is a cheaper way to go but those came with Dana 36 instead of 44 from my recollection.
But I wouldn’t worry about what suspension it has and go coil overs. I ran the stock z07 springs with koni yellows but it was a bit soft for the track. Decent street / track compromise I guess if you find a z07 or z51 car you could just change shocks and bushings and have a decent suspension to start with.
XLexusTech
08-11-2019, 06:55 AM
this looks interesting.. https://www.ebay.com/itm/1992-Chevrolet-Corvette/173991148398?hash=item2882ae3b6e:g:oOEAAOSwiMtcqse m
Dliccardi
08-11-2019, 07:29 AM
You can find better deals out there if you hold off. And C4racer is correct, any 88 and up will work.
Brizzle08
08-11-2019, 05:34 PM
Great thanks guys! So is the 6 speed always the better choice over the auto for pro touring? Thank you
c4racer2
08-11-2019, 06:12 PM
I was assuming a 6spd regardless if you use a ZF or a t56. Both will work btw. If you really want an AT I’m not sure why you want a corvette but that’s just my view. You can swap the Dana 36 for a 44 but that’s a lot of $ and could be hard to find the swap parts. You dont want a 36 if you have 400+ HP. They are rather weak Diffs.
Anyway point being start with a manual car if you can regardless what trans you plan to run. And honestly the ZF that comes in these is a great transmission and I personally would run one in such a build.
silvermonte
08-13-2019, 02:05 PM
the 96 comes with the 13" brakes , so thats something to think about, and has the OBD2
c4racer2
08-14-2019, 09:19 AM
Complete don't care IMHO. I would assume if you are building a PT car out of it he would be using a completely different motor - nothing based on a L98 or a LT1 - either a LSx motor or full hot rod EFI SBC or something. And I would completely throw away the factory wire harness and start over. It's a heavy complicated prone to failure mess. I built from scratch on the C4 race car build I did. And likewise I would not recommend factory C4 brakes - they are barely adequate for a stock C4. I would go Wildwood or adapt C6 ZR1 brakes or StopTech.
mike@sim-seats
08-18-2019, 11:11 AM
I believe the answer depends on your final goal. Do you want a street car that handles nice? Are you trying to win a particular class of racing?
If you aren't trying to build something to a set of rules whatever year the newest/nicest one you can find is the best year.
PS. avoid anything with a digital dash.
