View Full Version : C5 Corvette 13" to 14" brake rotor conversion
79 Camaro
08-08-2019, 05:19 PM
On my 68 C10 I'm running C5 Corvette front brakes with 20" wheels. They work well but the 20" wheel makes the 13" rotors look a bit small. I'd like to upgrade? to Z06 rotors which are 14" purely for looks only. I can remake the caliper mounts to move the caliper out the 1/2".
So my question does the 14" Z06 rotor have the same pad area so I can reuse my C5 calipers? I looked on online and they looked similar.
c4racer2
08-08-2019, 05:41 PM
the calipers may work but they would likely need to be moved .5" out to line up with the bigger rotor
79 Camaro
08-08-2019, 06:00 PM
Thanks for the reply. That's what I was thinking. I'm going to stop at NAPA tomorrow and see if they can order a cheap? Z06 rotor so I can compare. I may need to give KORE3 a call.
130fe
08-08-2019, 09:48 PM
You can switch to a C5/C6 Z51 setup from a normal C5. You just need the Z51 caliper abutment brackets and rotors. Gives you 13.5/13 (I believe) while using the same calipers. Call Tobin at Kore3!
Jaymzz
08-09-2019, 04:49 PM
I have a complete 2002 zo6 assembly you can borrow if you are around Oregon.
79 Camaro
08-10-2019, 12:16 PM
Thanks for the offer. I'm in MN. I may hit you up measurements if that OK.
Jaymzz
08-10-2019, 04:00 PM
Sounds good!
WallaceMFG
08-11-2019, 10:29 AM
I second what was stated above, look for C6 Z51 brakes, They will bolt right in and have plenty of stopping power with a 13.5" rotor. And cheaper than Z06 parts.
79 Camaro
08-15-2019, 04:25 PM
Just an FYI.
I got a 2007 Z06 rotor from NAPA. Drilled but not slotted. Comparing the Z06 rotor to the "stock" C5 rotor the pad area is 1/8" wider. No worries there. Both rotors have the same "back space" and hub bore diameter. Z06 rotor is 13.97" so I will need to make new caliper brackets that move the caliper out 1/2". Just to be clear my 2.5" drop spindles were milled, drilled and tapped on the back side to allow a bracket that bolts up to a C5 caliper abutment. It's just a flat piece of steel about 3/8-7/16" thick with four bolt holes. Two for the spindle mount. Two for the caliper mount.
Got a couple of months of driving before winter hits so it will be a winter project.
jlcustomz
08-15-2019, 04:49 PM
Other option may be CTS calipers, they bolt on extended as is. Just don't remember all the specifics right now
79 Camaro
08-15-2019, 05:25 PM
Thought about the CTSV Brembo calipers. A buddy of mine has them on his 89 Camaro LS swap. Great brakes. I want to reuse my C5 calipers.
jlcustomz
08-15-2019, 05:33 PM
Then bracket spacing em 1/2 up & call it done.
