2yellow69
08-04-2019, 05:32 PM
Hello all,
Let me start with what I had and then what I am running into.
1969 Camaro
Stock subframe with Speedtech Chicane coilover mounts (the upper control arm mounts are actually from the DSE coilover conversion that was done years ago). Varishocks coilovers. Global West upper and lower control arms. ATS AFX tall spindles. Unisteer rack and pinion. Speedtech engine frame stands and Speedtech LS adapter plates.
6.0 LS with Trailblazer SS intake manifold. Holley 302-2 oil pan. Lakewood bellhousing. TKO600. Everything fit. I decided to put 275's all the way around and found the subframe to be limiting me a bit. Decided to go with the complete Speedtech subframe and suspension package. Installed the subframe and suspension this weekend. Measured what seems like a hundred times to make sure the subframe was installed square to the car. Installed the engine/trans. Everything is going great until I notice how far forward the engine is sitting. I'm guessing it's close to 2 inches farther forward. The adapter plates are installed correctly and switching them from side to side would make the problem worse. I knew there would be differences to adjust for but I'm bewildered why the engine is so far forward. The back of the passenger side head is nearly 2.75" from the firewall!! I saw a recent post by AAQUINO11 (https://www.pro-touring.com/members/31225-AAQUINO11) about the same thing but no follow up to his issue. My main issues are; #1 my steering shaft no longer clears my headers (OK. not too surprised), #2 My ceramic coated exhaust is 2" too short (totally shocked about this one), #3 My shifter is up against the front of the cutout on the tunnel ( Not hard to make do). There are a couple of other issues but besides changing out the oil pan are easy to deal with. Looking at the pictures, I'm wondering if I got the correct upper control arms. Aren't the high clearance arms supposed to have a bend in the front tube?
Any ideas anyone might have would be appreciated. I'll have to get ahold of Speedtech later this week when I have some time away from work.
1969 Camaro
