Sleeper68
07-23-2019, 11:28 AM
Hello All,
I have been having an issue with my steering system randomly under heavy load ever since I switched back to recirculating ball from a crappy rack.
During hard slaloms, at some corner entries, and some corner exits a very abrupt and sharp feedback will come through the steering wheel which feels like a bind. This lasts far less than one second. It only happens when trying to turn in or straighten out the steering, under heavy load. I checked the steering output side (linkages, tie rods, steering arms, etc.) and suspension rigorously to look for interference and have found nothing.
Maximum steering wheel input when this issue occurs is 90 deg from center either direction. I have not as of now experienced this issue at all while driving normally on the street, ONLY during autocross or other very hard driving. No discernible odd noises or vibrations, although this is so abrupt and random that it is difficult to completely rule out. The engine is also quite loud so whining may be masked. The box does not appear to be leaking anywhere, nor does the rest of the system. System has been bled well and fluid condition is good, very little aeration, at least at idle.
The car is a 1968 Camaro. Steering specs: TurnOne 12.7:1 670 Delphi box, Saginaw TC iron case pump from Vintage Air w/ Front runner system for gen 1 SBC, -6 JIC pressure line, -10 JIC pump feed line, -6 JIC return lines, remote Allstar Perf reservoir, mocal inline PS cooler, Chassisworks Z/28 7075-T651 aluminum steering arms, factory drag link, Howe quick bump outer tie rods, short pitman and idler arm.
As for now I have two different suspicions but I will wait to reveal them as to not bias any suggestions.
Other than this random issue the steering is great. Good feedback, very linear, proper ratio, less then 0.030" bumpsteer over 4" of travel, etc.
Thank you all in advance for your help.
