View Full Version : rotational noise at 70+ mph
70chevellemalibu
07-23-2019, 05:28 AM
hey guys my 70 chevelle is making a high speed rotational noise heres the specs on my car and the story:
It has full UMI suspension, 4 wheel discs, 350CI, 200r4, 12 bolt 373s and posi.
Transmission and 12 bolt is freshly rebuilt, front wheel bearings are also fresh, drive shaft balanced, all 4 wheels balanced.
At city speed i do not notice the rotational noise (maybe the exhaust tone is masking it?) but i don't think so. Once i reach 70+ MPH i get a waaa quiet waaa quiet waaa quiet waaa sound no vibrations seems as smooth as it can be for a 50 year old car but its not as smooth as my newer sierra. This noise is not a constant waaaaaaaaaa sound its rotational.
Anyways i don't remember the noise being there last year and now its bugging me as i think there is something wrong with the diff.
Could the noise be tire noise or air chopping through the wheel wells or something? has anyone else experienced this?
Can anyone suggest any tips? i had the car looked at by the shop who rebuilt the trans and diff and they said they couldn't replicate the noise and everything seems tight and fine with the car but i want the car to be silent and perfect.....
GoodysGotaCuda
07-23-2019, 02:10 PM
What do the driveline angles look like? Binding/Unbinding u-joints can make a sound like that.
70chevellemalibu
07-24-2019, 04:46 AM
thanks for the tip i will look at the angles this week.
70chevellemalibu
07-26-2019, 08:23 PM
okay i have done alot of reading to make sure i understood what i have:
Here are my results using a digital angle finder.
1. put car on jackstands decently level.
2. place laser on belhousing and "zero".
3. place laser on bottom of the driveshaft: 85.8 degrees up with the laser upside down (magnet to the driveshaft). 85.8 - 90 = -5.8 or +5.8 i am assuming +5.8 due to drive shaft pointing up from the transmission to the diff.
4. "zero" laser on the driveshaft
5. pinion 88.7 degrees down: 88.7 - 90 = -1.3 degrees
6. trans 85.6 degrees down: 85.6 - 90 = - 4.4 degrees
Check math (Operating angles)
Transmission angle minus Driveline angle: -4.4 + 5.8 = 1.4 degrees (.1 degree off)
Transmission angle minus diff angle: -1.3 + 5.8 = 4.4 degrees (okay)
So if my optimal working angles are going to be 2 degrees i need to move the transmission up approximately 1/2" to obtain 2 degrees down and i need to get adjustable upper control arms to rotate the pinion back 1/2" to get the pinion 2 degrees up. (1/2" dimension based on using my snowblower chute to measure angles and distance).
does the above sound right?
thanks
andrewb70
07-27-2019, 06:31 AM
I can't really follow your math, because some of the things don't make sense. I can tell you that when A-bodies are lowered in the rear, it is impossible to get the drive-in angles set-up properly. In a stock configuration, when the frame is level, the engine points down to the rear about 3-4 degrees, the driveshaft points down to the rear 4-5 degrees, and the pinion points up a degree or two. So with stock rubber suspension bushings in the rear, under power the pinion rises and the front and rear operating angles essentially zero out, making things run smoothly.
When you lower the rear, the front operating angle forms a shallow V, instead of the shallow inverted V. As the pinion rises under power, the front operating angle increases, instead of decreasing as it would in a stock set-up.
I (and many others since) solved this in my 70 GTO by using a driveshaft with a CV joint in the front and a u-joint in the rear. These shafts are available from The Driveshaft Shop.
Your other solution is to try to raise the back of the transmission as high as possible in order to reduce the front operating angle.
The general rule is that, under load, the front and rear operating angles need to be equal, but opposite and as small as possible (under 3 degrees) but not zero.
joeko23
07-27-2019, 09:15 AM
It doesn’t make sense that your driveshaft is pointing up from tranny to rear. It should be pointing down. Unless ofcourse your rear is super low (above the tranny). First recheck that your driveshaft is actually pointing up when going from tranny to rear. Ideally you should see tranny pointing down about 3 degrees and rear pinion pointing up 3 degrees. That’s a 0 driveline angle which is ideal.
Also you just put the car on jackstands supported by the frame? If so this is wrong as well, besides putting the car on jack stands you have to support the rear by putting the tires on blocks or something to get it to ride height. When trying to find pinion angles the car must be at ride height.
andrewb70
07-27-2019, 09:28 AM
When A-bodies are lowered to what we like for ride height, the rear axle ends up being above the trans. My front operating angle in my 1970 GTO is 6 degrees, forming a shallow V.
70chevellemalibu
07-27-2019, 07:45 PM
Andrew what part doesn’t make sense?
This is the tutorial I used:
https://shiftsst.com/blog/post/driveline-angles.html
Some of your PDFs posted from spicer.
Also you are correct based on the angles i found yesterday I have a shallow V. I have about 1” available to move up before I hit the tunnel.
andrewb70
07-27-2019, 07:46 PM
I've said all I have to say.
70chevellemalibu
07-27-2019, 07:58 PM
Lol really? I’d like to know what I did wrong if anything. If I’m measuring wrong to begin with based on your comment you can’t follow my math, then your comment of you’ve said all you’ve had to say is leading me to fail.....
Some clarification would be nice because the way I understand all the posts and PDFs I’ve done it right...
andrewb70
07-28-2019, 09:18 AM
Here is how I would measure. I like to keep the angle finder orientation the same, because it eliminates having to do extra math that has to be done if you start orienting the angle finder 90 degrees out.
As noted before, the rear axle should be supported so that the weight of the car is putting the rear axle at ride height. The front wheels don't have to be loaded, but it helps, because of the slight change in weight distribution if you were to put the front jack stands under the frame. Ideally, make some wheel stands from 2x4s and put them under the front and rear tires. This makes the car very stable and basically mimics the position as it would be on the ground. The frame does not have to be level.
I would then find a horizontal plane on the block that is parallel to the crank (by definition this will also be parallel to the transmission output shaft). If you have a billet slip yoke, it will have such a location, if not, then there are various surfaces on the block that can be used.
Take the measurement. If the frame happens to be close to level, that measurement will likely be 3-4 degrees, pointing down to the rear. If the frame is not level due to stance, etc. that's OK, just be aware of the direction of the measurement. If you have a lot of rake, the measurement could be zero or even pointing up to the rear. Write this number down.
Then measure the driveshaft angle in the front and in the rear. If the front angle and the rear angle don't match...that's very bad :-) Again, take careful note of the direction. This can get tricky if the driveshaft is close to level (which it might be!). Write this number down.
Those two numbers are all that you need to figure out the front operating angle. For instance:
If the engine is 3 degrees pointing down to the rear and the driveshaft is zero, then your front operating angle is 3 degrees, forming a shallow V. As I said before, in a stock car, this angle would be an inverted V.
Now, measure the pinion angle. Again, you want to find a surface that is horizontal, which avoids confusion. If you have a billet rear yoke, it will have a suitable surface to measure. If not, you may have to resort to measuring vertically off the u-joint caps, but take extra time to note the direction, etc...write this number down.
You now have all the information you need. To figure out the rear operating angle, use the angle of the pinion and the angle of the driveshaft.
Since the angle of the driveshaft is the same front and rear, we can do our calculation. Using the previous example where the driveshaft was level, and the pinion gear pointing down toward the front at 2 degrees. Your rear operating angle is 2 degrees, also forming a shallow V.
The numbers in the above example are not uncommon and present a problem. Remember what I said about the end goal:
"The general rule is that, under load, the front and rear operating angles need to be equal, but opposite and as small as possible (under 3 degrees) but not zero."
I don't agree with the link you posted, because they state that at 3500RPM driveshaft speed, the max angle can be 5 degrees. While that might be the MAX, it will not give you smooth operation, or at least that has been my experience.
You said you have 3.73 gears, you did not state tire height, but assuming a 275/40-17 tire, which is 25.66" tall, at 70MPH the driveshaft is spinning 3420RPM!
Let's go back to our hypothetical example. Front operating angle is 3 degrees, forming a shallow V and rear is at 2 degrees, also forming a shallow V. Keep in mind, these are static numbers, without load! So what happens when power is applied? The pinion wants to rise up. How much or how little greatly depends on your rear suspension bushings. Soft rubber bushings will deflect A LOT! You can find plenty of videos on YouTube of that. Even poly bushings deflect quite a bit, and frankly you should not be using poly bushings at all 8 points in the rear suspension, but that's another discussion.
So, let's assume that under a light load, on the highway, you have 2 degree of pinion pinion rise. What does that do for our operating angles?
We started with 3 front, shallow V and 2 rear, also shallow V, but now the pinion is further up by 2 degrees and the rear operating angle is at zero degrees and the front is more than 3 degrees. You can use some geometry and trig to figure out the exact angle, but we don't need to know exactly, all we need to know is that our angles are out of whack, under load:
Front is < 3 and rear is zero. This does not follow the required guideline, so what do we do to fix it?
You can shorten the upper rear control arms and tilt the pinion down to the front a little more. This will change both the front and rear operating angles, because the driveshaft is attached to the pinion gear, so you will have to rinse and repeat your measurements and reevaluate. You can also raise the back of the transmission some, but you can only go so far before the front slip yoke hits the floor or the accessories start crashing into things.
I have gone over this many times in my 70 GTO and ultimately went with the CV driveshaft, and many have done so as well. In my Cougar I actually have a CV joint at the front and at the pinion. I have 4.33 gears and 25.5" tires and routinely spin the driveshaft to 5000RPM on the highway (about 80mph). It's as smooth as a new car.
I hope this helps.
70chevellemalibu
07-29-2019, 06:09 AM
thanks for the in depth description ill get back under the car this week.
Currently the jack stands are on the rear diff and the front of the car is on ramp therefore the car is resting and ride height but it may not be 100% level.
Do you use the digital levels or one like this:
https://static.grainger.com/rp/s/is/image/Grainger/11LP29_AS01?$zmmain$
andrewb70
07-29-2019, 06:16 AM
I use a digital angle finder I got at Home Depot. I think it is their Husky brand.
70chevellemalibu
07-29-2019, 07:46 PM
Okay see the attached files for my results.
No where close to being equal, I’ll order up some UMI rear adjustable and play with shining the transmission.
FYI I have 6 poly bushings in the back and 2 rubber.
Thanks Andrew
andrewb70
07-29-2019, 08:03 PM
Good job.
Unfortunately, if you get adjustable rear upper control arms and make them shorter, the front angle will get much worse. As you see, your number are very close to my hypothetical numbers, which is not by accident. I've dealt with this before.
70chevellemalibu
07-30-2019, 03:39 AM
Right I would have to make the control arms longer, should i not bother with buying the arms and just try to raise the trans And ultimately buy a cv joint shaft? Or do the arms have enough adjustment to get me to at least pointing up? I just had my driveshaft cut and rebalanced for my new transmission and 12 bolt. I’d hate to have to buy another shaft.
andrewb70
07-30-2019, 05:42 AM
You're right. It was late when I responded. Yes, uppers would need to be longer, but that will only make the front operating angle worse. Mine is at 6 degrees in the front and 1 degree down to the front in the rear. Mine is worse than yours because lsswap, etc...
Tsaints1115
07-30-2019, 08:18 AM
Isn't these angles not as sensitive if one runs cv joints on the drive shaft as you've mentioned?
70chevellemalibu
07-30-2019, 08:53 AM
So if im visualizing this right i need to buy the adjustable rear arms and make them longer so i can move the pinion up by doing this it also changes the angle of the joint at the transmission and also moves it up but at a different rate than the diff which is why you recommend shimming up the transmission.
Im going to have to buy the arms and shim the transmission and hopefully find a sweet spot without needing a $1000 USD shaft unless i can modify my shaft to have a CV joint in the front with a regular u joint in the rear like yours?
Like you said my angles are not as aggressive as yours so i might be able to make small movements to get me dam close.
sound good to you?
andrewb70
07-30-2019, 09:27 AM
Before spending any money, see how far you can raise the trans. I suspect, maybe 1" at most. Remeasure. The second step would be to temporarily adjust rear ride height and see if the vibrations improve.
Chasing these issues is very frustrating and the last thing you want to start doing is throwing parts at it.
Another thing you need to do is check the run-out of the driveshaft, front and rear.
70chevellemalibu
07-30-2019, 07:07 PM
Here’s tonights math I think I’m pretty dang close .5 of a degree out with the trans lifted about an inch.
I might even be there if you think I have less uplift with my poly bushings versus the rubber.
andrewb70
07-31-2019, 06:19 AM
The output shaft of the transmission and the pinion gear need to be parallel.
https://static1.pt-content.com/images/pt/2019/07/shaftangle-1.jpg
70chevellemalibu
07-31-2019, 06:45 AM
Ive been playing with it a bit more and i think i have have her licked.
1. Angle at the block 2 degrees down.
2. Driveshaft angle at transmission output .5 up towards diff.
3. Driveshaft angle at diff .5 up towards diff.
4. Pinion 2.5 down
Engine operating angle: = 2 - 0.5 = 1.5
Diff operating angle: = 2.5 -.5 = 2.0
Add pinion uplift using 1.5 degrees because of poly bushings (is this acceptable?)
= -2.5 + 1.5 = -1
New rear operating angle = -1 - 0.5 = - 1.5
Final outcome:
Front operating angles + 1.5 degrees
rear operating angles - 1.5 degrees
andrewb70
07-31-2019, 06:47 AM
Go drive it...LOL
70chevellemalibu
07-31-2019, 06:53 AM
whoo hoo!
thanks Andrew I'm going to get a spacer built and test it out.
thanks again for your help, your detailed description helped me understand what i was actually doing instead of just following a tutorial.
70chevellemalibu
07-31-2019, 07:05 AM
one comment i do have is why didnt i feel any vibrations why was i only hearing a rotational sound?
andrewb70
07-31-2019, 07:09 AM
Beats me? Maybe you did all this for nothing and it is something else entirely :-)
70chevellemalibu
08-13-2019, 06:28 PM
So everything is set up and the noise is still there it’s definitely smooth and I feel confident taking it up to higher speeds but the noise is still there maybe the pitch of the noise is not as loud at 65-70 as it was before...
The noise definitely is not there until 65-70 and is there up to about 85 I didn’t push it any higher but seemed the noise got louder the faster I went.
Any ideas on what to try next?
sccacuda
08-14-2019, 07:50 AM
Put it on a 4 post drive on lift, raise the rear axle, and drive it up to speed. See if the noise is still present with no load on the tires or wheel bearings. You can get under it while it's making the noise and hunt around with a stethoscope. Driveline noises are tough to find because they transmit through the drive shaft and axle. Have you tried changing lanes suddenly when it's making noise? This can help identify a wheel bearing by loading/unloading one side for a second.
raustinss
08-14-2019, 01:20 PM
Without reading everything here , have you checked u joints and axle bearings as well
70chevellemalibu
08-15-2019, 10:10 AM
All wheel bearings and axle bears are new and u joints are new and tight.
How would I convince someone to get the car on a 4 post and bring it up to speed? To check with a stethoscope? Does it need to be going 70-80 mph on the hoist or will it be able to be heard at a slower speed?
One thing to note that has me wondering is my x pipe is touching my cross member, it doesn’t rattle but is there a chance there’s noise coming off that at 2000 rpm?
raustinss
08-15-2019, 03:46 PM
Convince then with beer , slide them some money , strap it down good , pray to teenage jesus and giver
70chevellemalibu
08-15-2019, 07:11 PM
Would this type of rhythmic noise that I’m hearing be tire noise?
I can’t swap my rims front to rear due to the stagger, my truck has a bad mud tire noise but it’s constant throughout all speeds which makes me think this isn’t the case with the chevelle, correct?
raustinss
08-16-2019, 10:11 AM
Where are you located
Peter Mc Mahon
08-16-2019, 02:16 PM
Sounds like pinion gear noise. Fairly hi pitched? If it is doing it at a steady speed, and you then accelerate does it go away?
Same scenario, if it is doing it at a steady speed and you let off the gas does it go away?
Shift to neutral at speed and it goes away?
70chevellemalibu
08-16-2019, 07:55 PM
I’m in Manitoba.
Peter i have pinion gear noise at 50 mph +\- 5 mph high pitch whine.
The noise I am hearing is 100% rotational oscillating (on off on off on off) no vibration baby smooth up to 80 mph feels safe but the noise is there. The noise starts at 70 and gets faster the faster I go.
It’s not a constant bad bearing noise all all speeds or if I jerk the steering it doesn’t go away. It’s strictly related to the speed I am traveling.
Peter Mc Mahon
08-17-2019, 12:50 AM
Still sounds like what I have had in the past. Try the questions that I asked and see what happens. Mine was smooth as glass, no vibration, on off on off.
70chevellemalibu
08-17-2019, 11:06 AM
The oscillating sound isn’t high pitched, it does it 70 mph threw to 80 probably does it above but I have gone that fast yet doesn’t go away until I’m below 70.
What you are describing happens to me at 50 mph +\- 5 mph.
andrewb70
08-17-2019, 11:45 AM
Just out of curiosity, what tires are you running?
70chevellemalibu
08-17-2019, 12:03 PM
Im miss matched for now.
new falken azenis rt615k 255/40/17 in the front.
older Nitto nt555 285/40/17 in the rear
i bought the rims used and they came with bald fronts and newer rears.
andrewb70
08-17-2019, 12:13 PM
I've had those tires on my GTO before (not simultaneously) and I never had much road noise from the tires.
Peter Mc Mahon
08-18-2019, 02:07 AM
What happens if you shift to neutral while it’s happening?
70chevellemalibu
08-18-2019, 05:33 AM
I think it goes away.
Went 80 shift to neutral noise went away; i had to do it a few times as when I left off the gas and shift into N the car slows down also.
If this is in fact pinion noise like you suggest can I leave it this way? Where I live our speed limits are 60 mph so it’s not like I do 80 everyday. Is there premature wear happening that could result in a part in the diff breaking and causing tire lock up at highway speeds?
andrewb70
08-18-2019, 05:38 AM
This can easily be the ring and pinion making noise. R&P noise is odd, because it can manifest while under load, or off load, depending on the particular gear set.
At this point I don't think that it is related to driveline angles, since you don't have a vibration.
joeko23
08-18-2019, 05:46 AM
You mentioned that your exhaust is touching the tranny cross member I believe. I wouldn’t discount that as being the source of your sound. It could be certain rpm produces certain vibration that translates to a harmonic noise in the car. Try to adjust so it’s not touching. Could be an easy fix. Maybe wrap the part that’s touching with exhaust insulation and the cross member as well just to create some sound barrier (just as a temporary fix).
Peter Mc Mahon
08-18-2019, 11:49 AM
In my opinion you can leave it alone if that’s the problem. I drove my old 70 dart like that for years.
