View Full Version : Very high pedal effort with Willwood’s
g356gear
07-14-2019, 10:25 AM
I took the car out for the first time today since last fall, and the pedal effort is super high to get the brakes to engage. I have a stock dual master and power brakes. Does this sound like something a brake bleed might cure? Fluids levels in the master are up, and there are no leaks anywhere.There was no issue when it was parked. Thanks!
andrewb70
07-14-2019, 11:39 AM
What is the MC bore size? Are you certain the booster is working? Does the engine make enough vacuum to operate the booster?
GoodysGotaCuda
07-14-2019, 11:54 AM
Sounds like a vacuum problem. When you shut off the car, does the pedal go immediately hard? or do you get a couple pumps of assist?
g356gear
07-14-2019, 12:10 PM
I just double checked everything and it looks like the plastic grommet at the master cylinder had cracked with age and heat. They would explain my lack of vacuum. Thanks!
andrewb70
07-14-2019, 12:14 PM
That would do it! Please report back once it is fixed.
