View Full Version : LS oil pan - lowest profile -
1sikride
07-08-2019, 07:50 AM
Hey guys.
6.2 LS
the whole install kit is
holly.
I noticed today my oil pan is dimpled
pretty bad on both sides from the ball joints.
Aka bad friggin news...
holly isn’t being helpful.
Ls swap shop I used isn’t either...
rack and pinion is an option. Be it a super pricy one.
Shim the engine up a bit?
i heard this is possible and not.
Temp solution..
back fill the dimples
and weld a little protector plate so the ball joint
cant puncture the pan ????
frig. I’m frazzled here
dontlifttoshift
07-08-2019, 09:26 AM
Do not put a rack and pinion on your car.
What is the part number of your pan? It "looks" like the 302-1.
https://static1.pt-content.com/images/pt/2019/07/3021_3022comp1-1.jpg
1sikride
07-08-2019, 12:00 PM
Ya it is.
holly told me there’s an even
Newer one out now. Looks like
The one you showed.
I’m trying to get them to swap
It out for me
slimjim
07-08-2019, 12:08 PM
Mast motorsports pan may be a solution
https://static1.pt-content.com/images/pt/2019/07/aRLMyS2-1.jpg
1sikride
07-08-2019, 01:31 PM
So Holley is being difficult.
I’m using 302-1
I have the 71221007HKR
Mounts.
He’s saying those are mis matching
Comments. I ordered what I was told
To by the swap shop who’s done
At least 50 swaps. Nothing but
Sexy hot rods coming n going...
Any insight?
Build-It-Break-It
07-08-2019, 01:41 PM
Ordering the 302-2 looks like your best and easiest solution.
1sikride
07-08-2019, 01:42 PM
Looks like. But I’m miffed they won’t help
Me out and are telling me I mismatched
Parts...
I can’t find anything saying I did
Mismatch
andrewb70
07-08-2019, 02:12 PM
The instructions for the Holley mounts that you are using clearly state that the 302-2 pan is the one to use.
https://documents.holley.com/199r10933.pdf
You have a 302-1 pan. The 302-3 pan will also work, because it is identical to the 3.2-2, except with additional clearance for a stroker crank and two oil drain back ports for turbo applications.
andrewb70
07-08-2019, 02:24 PM
Here is how a 302-2 pan fits in a A-body.
https://static1.pt-content.com/images/pt/2019/07/img_1455_a498feaba05a4d41fe3c43951e3c2a5-1.jpg
https://static1.pt-content.com/images/pt/2019/07/img_1456_8f87ef0282470439b713d320a3d9b90-1.jpg
1sikride
07-08-2019, 03:50 PM
Teenie tiny
1sikride
07-09-2019, 06:41 AM
Do you guys know if the windage
Trays are swapable from
The 302-1 and 302-2???
Anyone interested in my
Old pan cheap ?
andrewb70
07-09-2019, 06:44 AM
Old pan cheap ?
I believe the 302-2 requires a little extra trimming. Consult the instructions I posted.
parsonsj
07-09-2019, 08:27 AM
Looks like. But I’m miffed they won’t help me out and are telling me I mismatched parts...It seems your issue is with the shop who did the work, not Holley.
Toddoky
07-09-2019, 04:16 PM
Nowhere in Holley literature or website listings is the Holley 302-1 oil pan listed to be compatible with the Hooker Blackheart A-Body LS swap system. It is specifically stated that the 302-2 and 302-3 pans are to be used in that application. The shop recommended the 302-1 pan in error.
KiwiStarChief
07-09-2019, 06:42 PM
Old pan cheap ?
How cheap is cheap 1sikride?
1sikride
07-10-2019, 01:26 AM
Ya I’m learning this...
andrewb70
07-10-2019, 06:18 AM
Learning what, exactly?
GS455vert
07-28-2019, 06:12 PM
Not to hijack this thread.... BUT I have a 67 Chevelle with a LS2 in it. This car was an early swap car done with a 2007 GM create (corvette) engine and used energy poly mounts and what looks to be new fame mounts. The drive angles are extreme (2-3 on driveshaft and pinion. 8 on trans yoke) due to trans tail down and a lowered stance. Serial # says it is 2007 corvette create engine and has stock type pan on it. What can I do to fix this thing properly? Was thinking Holley 302 pan, Dingo mounts and trans blocks. Opinions please??
968ls1
07-29-2019, 12:26 PM
Use the Holley engine mounts, 302-2 or 302-3 oil pan and the Holley trans X-member.
andrewb70
07-29-2019, 12:42 PM
The Hooker (Holley) swap components will greatly help your drive-in situation. I have the same issue on my 70 GTO (swap done in 2008) and eventually I will redo the swap with the Holley parts.
https://www.holley.com/products/engine_swap_parts/ls_swap_systems/1964-67_gm_a-body_ls_swap_components/
68conv455
07-29-2019, 04:09 PM
I used the holley frame mounts, 302-2 pan, Hooker headers, and holley accessory drive on my 68 cutlass. All fit perfectly with no issues.
No reason anymore to create new solutions for common swaps.
