View Full Version : Torque = Hp x 5252 / Rpm (5252 is a constant) - still a valid formula ?
67-LS1
07-07-2019, 07:32 AM
With today’s engines where torque output can me “manipulated” by manufactures through electronics, variable cam timing, etc to be more consistent across wider RPM ranges, is the long held formula of torque = HP x 5252 / RPM still valid?
andrewb70
07-07-2019, 10:02 AM
Yes, #becausephysics
67-LS1
07-07-2019, 10:49 AM
So how dies one explain torque curves that say reach peak torque at 1800 rpm and hold it constant until 2400 rpm while hp rises from 260 to 300 over the same span?
andrewb70
07-07-2019, 10:51 AM
Variable valve timing, variable vane turbo, advanced engine management strategies.
67-LS1
07-07-2019, 11:15 PM
So in cases of new engines with new technologies, the original theory is no longer valid?
In my example torque is 258 lb ft at 1800 rpm AND at 2400 rpm.
So....
258 lb ft = 260 HP x 5252 / 1800 RPM. FAIL. Calculation shows 758.6 lb ft
258 lb ft = 300 HP x 5252 / 2400 RPM. FAIL. Calculation shows 656.5 lb ft
JustJohn
07-08-2019, 04:12 AM
You are correct. I've never seen a flat torque curve before.
cornfedbill
07-08-2019, 04:20 AM
There is a lot that can be done with today's electronics, variable cam timing, variable turbo boost and direct injection that we could never have dreamed of in the days of carburetors and point type ignition. Torque curves are increasingly flat. That means the horsepower curve is more linear than ever before.
The formula remains true because that is how horsepower is defined. We cannot measure horsepower, only torque and speed. from this, horsepower is calculated.
Most new direct injected and turbocharged cars have very flat torque curves. This is great. It sure beats the big-cammed cars of the 60's and 70's that would not wake up until 3000 rpm and were done at 7000 rpm. Now the problem is getting transmissions to survive under the high torque loads.
andrewb70
07-08-2019, 05:43 AM
So....
HP = (TQ X RPM) / 5252
An engine can make the same torque at different RPM, what changes is the HP. As RPM climbs, so does HP.
https://spicerparts.com/calculators/horsepower-torque-calculator
sccacuda
07-08-2019, 06:00 AM
So....
The formula is the ONLY way engine power is calculated. It has not changed, nor will it. The formula is correct, I think your math is off a little.
HP and TQ will ALWAYS be equal at 5252 RPM. This is the way the formula was originally produced, and right or wrong, is how all engines, electric motors, or any rotating device that produce work is measured.
258 lb. ft @ 1800 RPM = 88.4 HP (258 x 1800) / 5252 = HP (464,400) / 5252 = 88.4 HP
258 lb.ft @ 2400 RPM = 117.9 HP (258 x 2400) / 5252 = HP (619,200) / 5252 = 117.9 HP
The formula can be changed to find TQ, but HP and it's RPM must be known.
67-LS1
07-08-2019, 06:46 AM
In my formula, I didn’t make up the given HP or torque numbers. They are all from a torque curve. I can’t figure out how to attach it or I would.
I believe it when you say the formula is tried and true but how does that jibe with engines that have these new flatter curves?
Is this formula for “peak” torque or HP only?
Or is it how HP is “Defined” as Bill states above as opposed to “Measured”?
andrewb70
07-08-2019, 06:52 AM
Torque is what is measured directly. HP is a measure of work performed over time, which is why RPM matters.
sccacuda
07-08-2019, 07:00 AM
It jibes exactly to the mathematical formulas solution. It is not just tried and true, it is the ONLY way it is measured and is defined by the formula. As I said, your math is off.
I guarantee you that any HP or Tq numbers at a given RPM is derived from this formula, peak or at any other RPM. All dynamometers use this programmed formula to calculate HP and TQ.
Not to be an ass, but this formula is not wrong, it is used by everyone in the world as the only way to correctly measure HP and TQ. When you find where your making your math error, you'll see that it works too...simply because it cannot NOT work!!
sccacuda
07-08-2019, 07:18 AM
Your not understanding something. If your using a TQ curve as a reference, it was calculated with this formula. It doesn't matter if it's flat, peaky, or looks like a mountain range.
Are you sure your not looking at a hybrid vehicle that is factoring in the electric motors TQ into the advertised power output?
cornfedbill
07-08-2019, 07:20 AM
The formula shows the relationship between torque and horsepower at a given engine speed, not at the peak. If you use peak horsepower for the input, you need to also use the rpm at that peak. The same for torque.
Normally peak torque and peak horsepower are not at the same engine speed.
67-LS1
07-08-2019, 08:02 AM
OK! Figured out how to attach the curve!
I clearly don’t understand this, hence my OP and I do appreciate you guys trying to explain it. I know this formula is tried and true and has been since the invention of the horse.
But then I see a curve like the attached and hopefully you can see why I ask the question. The HP curve rises as the torque curve remains flat.
68Formula
07-08-2019, 08:09 AM
You need to convert your units from kW to HP first.
andrewb70
07-08-2019, 08:19 AM
HP is rising because RPM is rising!
79-TA
67 LS1, where did you get your example numbers from? Please double check them for accuracy. Make sure you haven't combined a peak horsepower with a peak torque that occur at different rpm's. Also, make sure that the torque and horsepower scales on the sides of the chart are accurate. Most of the time, torque and horsepower are scaled to use the same Y values on a chart. When torque and HP are scaled differently or use a different set of units (like Newton meters), the chart can be misleading.
67 LS1's math looks correct. As for the formula, it still holds true.
First, let's write the formula in the more familiar form where horsepower is isolated and shown as a result of RPM and torque:
HP = Tq(ft-lbfs)*RPM/5252
Now, let's do some review to appreciate what the units mean.
Force - a push or pull on an object
Energy or work - Force times distance
Power - Energy expended over an amount of time
Torque - rotational force
The relationship should be apparent now. Horsepower is a direct result of the product of torque and rpm, or put more simply, force and speed. More force (or torque) will create more horsepower and more speed (RPM) will create more horsepower just like less of either will reduce horsepower.
Next, let's do a quick unit analysis to demystify the 5252 constant.
1 HP = 550 ft-lbf/sec
1 RPM = 2pi radians/60 seconds
HP = X ft-lbf * Y RPM * (2*pi radians/revolution)*(1min/60 sec) * (1HP/(550 ft-lbf/sec))
HP = X ft-lbf * Y RPM * (2*pi/(33000))*(radians/revolution)*(min/sec)*(HP/(ft-lbf/sec))
HP = X * Y * 5252 HP
This is a physical definition of what is happening. It works for any kind of rotating motor (so long as we're using HP and ft-lbf) whether it's a gas engine, a bike crank, an electric motor, or a kid standing on the end of a lever.
Because the RPM changed the HP changed. You changed one variable in the formula (RPM) so the result has to change.
cornfedbill
07-08-2019, 08:25 AM
It rises because rpm is increasing. When torque is flat, horsepower increases linearly with rpm. Horsepower is torqueXrpm/5252.
If torque from 1000 to 6000 rpm is 100 ft.lb, then horsepower will be:
1000 rpm - 19 hp
2000 rpm - 38 hp
3000 rpm - 57 hp
4000 rpm - 76 hp
5000 rpm - 95 hp
6000 rpm - 114 hp
Does that make sense now?
79-TA
07-08-2019, 08:27 AM
Thanks for posting the chart. The 5252.113 unit conversion is specific to ft-lbf and horsepower.
For Newton-meters and kilowatts, the formula would be as follows:
KW = Tq (Nm) * RPM / 9549.3
sccacuda
07-08-2019, 08:38 AM
Lets just pick an RPM from the graph, say 1800 RPM. It's making roughly 350 Nm of torque, convert that to Lb. ft. and you get roughly 258 Lb. Ft.
258 x 1800/5252 = 88 hp. At the same 1800 RPM on the graph, it shows 65 KW's of power, convert that to HP and guess what, 88 HP.
Try it at any RPM point on the graph and you will get the same results. The formula with always be correct!!
parsonsj
07-08-2019, 09:14 AM
Right -- just piling on here, but the relationship between HP, torque, and RPM isn't "tried and true". It's true by definition:
1 horsepower is a unit of power equal to 550 foot-pounds per second (745.7 watts).
cornfedbill
07-08-2019, 11:21 AM
What he said! :twothumbs
CarlC
07-15-2019, 01:26 PM
Getting the units right in any engineering exercise may just save a life.
Just sayin....
cornfedbill
07-16-2019, 04:42 AM
Just sayin....
I always wonder why by doctor and lawyer friends just "practice", when as an engineer I have to get it right every time.
Right every time... that's what the safety multiplier is for!
cornfedbill
07-16-2019, 05:47 AM
Yup!
MonzaRacer
12-07-2019, 05:32 PM
All engines power is measured by torque, we get HP by an equation. Physics isn't hard if you understand what hat there are some constants in the world.
