View Full Version : Serpentine Moves forward on A/C compressor pulley
greenlight
06-20-2019, 04:57 PM
The Serpentine belt moves forward two grooves (up and over the A/C compressor pulley). We've ground the bracket to move the compressor pulley forward twice & replacing the belt too, but is still moves the same amount. It's a 67 Camaro with an LS3 out of a 2011 SS Camaro, Holley Accessory Drive System Part# 20-138. I'm open to suggestions, thank you!!
Greenlight
minendrews68
07-03-2019, 05:19 AM
something's out of alignment. either the A/C compressor is too far back or it's crooked relative to the other pulleys would be my guess.
Tsaints1115
07-03-2019, 01:55 PM
There’s alignment front to rear but also all pulley center lines need to be parallel.
morrisclassic
07-03-2019, 02:34 PM
Greenlight,
I had the same issue about drove me crazy!
Put a combination adjustable level vertical on
the crank pulley, rotate the dial until it is level.
Lock it down. Now put it on the A/C pulley
adjust the A/C pulley to be level also. This will
align the A/C pulley at the same degree as the
crank pulley. Hope this helps
Billy
