View Full Version : Coil over trouble JRS suspension.
XLexusTech
06-20-2019, 04:01 PM
Front suspend = JRS apex C6 based suspension.
Qa1 Coliovers:
When i take the weight off the wheel and allow the suspension to hang he upper arm hits the spring unless I screw the lower spring adjuster on the coil-over almost all the way up which make the ride height too high.
if I try to lower the spring adjuster down, to get the right hight down.. the spring will unseat less then half of the way down the adjustment, it will sit once i put weight on it but that seems wrong..
I wouldn't be shocked to hear I need different springs.. smaller diameter or fee length.
Thoughts appreciated..
dhutton
06-20-2019, 04:55 PM
Couple of thoughts.
Your coilover shock should be roughly centered in its travel at ride height. Is it?
If it is and the spring is not seated I think that says your spring is too short. Maybe post a couple of pics.
Don
XLexusTech
06-20-2019, 05:36 PM
Couple of thoughts.
Don
Thanks Don ... will get some pics when I can (car is about 2 hrs from home at shop.
I would say no shock is closer to fully extended then middle with car on ground
dhutton
06-20-2019, 05:49 PM
Is the car complete? Worrying about springs and ride height etc before the car is at its completed weight will drive you crazy.
Don
XLexusTech
06-21-2019, 03:23 AM
Don
Yeah this is why I haven’t acted on it. So for the first time in 2 years my car has been in the body shop. Got it on a lift the other day and remembered this. It has no front sheet metal on it so maybe that weight will change things ... one of th3 things that has me nervous is Whalen I first got my car back from jake he didn’t have the billstienes. Shock I paid for. A year plus later I got QA1 shocks and no springs from him ... so they may be wrong
dhutton
06-21-2019, 04:14 AM
How long are your springs? What rate? My first guess would be 10 inches and 500 lb/inch.
Don
