View Full Version : HELP!!! Power steering issues... continued
Just 1 More
06-17-2019, 04:12 PM
'68 Camaro, Concept One serpentine system. Took the car for an 80 mile run last week and everything was great. Next morning, no power steering. Sent the pump back to Concept One and they said it wasn't holding pressure so sent me a new one. (great customer service)
Got the new pump today, installed it, filled with fluid, fired up the car and still no power steering https://static1.pt-content.com/images/pt/2019/06/angry-1.gif
Pulled return line, fired it up and good fast flow.. reconnect, fill with fluid and again, no PS. Each time, I turned the wheel lock to lock several times trying to bleed the system of air.
Could it be the gear box? What and how do they act when something goes bad in them? I'm so freakin not happy right now https://static1.pt-content.com/images/pt/2019/06/mad-1.gif
Just 1 More
07-02-2019, 04:02 AM
I've been researching gear boxs, don't care to do anything used or rebuilt
CPP 50004 14:1 $379
AGR 492117 12:1 $431
Borgeson 800130 12.7:1 $445
PSC SG254B 12.7:1 $475
Turn One $800ish too much $ for my budget
I've been warned to stay away from the CPP & AGR.. anyone have any comments on this? I was also told the PSC is a great box, comments?
I'll be at Good Guys Columbus in 2 weeks, do the vendors do any type of show deals?
07-02-2019, 12:38 PM
I’ve used a couple of AGR boxes with good results. They bolt right in with no adapters. Borgeson should be good too.
UMI Tech
07-03-2019, 09:27 AM
Turn One is usually at Columbus. Even if you're not buying a new box it would be worth talking tech with Jeff or Junior. They're very helpful.
ramey
Just 1 More
07-05-2019, 05:03 AM
I tore the pump down, again, and found metal dust lining the edges of the reservoir and specs of stuff inside the valve. It's time for a completely new system, pump, box & hoses
I spent some time on the phone with AGR and we discussed pretty much everything in a PS system.. couldn't believe they took the time with me like they did,, For that, they've earned my business.
i'll be doing they're 492117 box 12.7:1 ratio
